i am looking for dac which has 12 bit resolution , dual channel , +/- 10v,+/-5,0-5v and 0-10v, which should require only single supply voltage of 5V,will u people help me to find out the device please
Hi Senthil,
I am not sure you are going to find a DAC with those ranges that will require only a single 5V supply. If you want a high voltage output (+/-10V) you are going to need higher supplies in order to power the DAC's internal op amp. Regardless, the DAC7716 is probably your best bet if you want to use a single chip solution.
Tony Calabria
