I have removed CCSv5 and have been trying to install CCSv6 on my laptop that's running Linux (LXLE) 14.04. I have tried using both - the web as well as the offline installer. Also, prior to running the ccs*.bin file I had resolved the dependencies as instructed on the wikipage for CCSv6.
I have attached the log file.
What is it that I have missed out or is there something that I am doing wrong?
4062.ccs_setup_6.1.0.00104_install.log
07/30/2015 19:49:45(GMT) - Validation::linuxLibChecks - LD_LIBRARY_PATH == :/tmp/ccs_c2f139ea-fea9-4ab8-7ce1-7ccfaa965d33/tcl/lib 07/30/2015 19:49:45(GMT) - Validation::linuxLibChecks - tempLD == {} 07/30/2015 19:49:45(GMT) - Validation::linuxLibChecks - cmd = /tmp/ccs_c2f139ea-fea9-4ab8-7ce1-7ccfaa965d33/dependency-checker/check_depends.sh --ldpath 07/30/2015 19:49:47(GMT) - Validation::linuxLibChecks - ran /tmp/ccs_c2f139ea-fea9-4ab8-7ce1-7ccfaa965d33/dependency-checker/check_depends.sh --ldpath :Installed versions of glibc and glibcxx: GLIBC_2.18, N/A Required versions of glibc and glibcxx: GLIBC_2.11, GLIBCXX_3.4.15 Checking availability of libraries in ext-depends.txt ... Done. 07/30/2015 19:49:47(GMT) - Validation::linuxLibChecks - Line: Installed versions of glibc and glibcxx: GLIBC_2.18, N/A 07/30/2015 19:49:47(GMT) - Validation::linuxLibChecks - Line: Required versions of glibc and glibcxx: GLIBC_2.11, GLIBCXX_3.4.15 07/30/2015 19:49:47(GMT) - Validation::linuxLibChecks - Line: Checking availability of libraries in ext-depends.txt ... 07/30/2015 19:49:47(GMT) - Validation::linuxLibChecks - Line: Done. 07/30/2015 19:49:53(GMT) - Util::httpCopy - http::config now: -accept */* -proxyfilter http::ProxyRequired -proxyhost {} -proxyport {} -urlencoding utf-8 -useragent {Tcl http client package 2.5.5} 07/30/2015 19:49:53(GMT) - Util::httpCopy - Downloading /tmp/ccs_c2f139ea-fea9-4ab8-7ce1-7ccfaa965d33/apps_6.1.0.json from http://software-dl.ti.com/ccs/non-esd/ccs_appcenter/apps_6.1.0.json 07/30/2015 19:49:56(GMT) - Util::httpCopy - httpstate= Server: Apache 07/30/2015 19:49:56(GMT) - Util::httpCopy - httpstate= Last-Modified: Mon, 22 Jun 2015 15:55:10 GMT 07/30/2015 19:49:56(GMT) - Util::httpCopy - httpstate= ETag: "662d-5191d4c653380" 07/30/2015 19:49:56(GMT) - Util::httpCopy - httpstate= Accept-Ranges: bytes 07/30/2015 19:49:56(GMT) - Util::httpCopy - httpstate= Content-Length: 26157 07/30/2015 19:49:56(GMT) - Util::httpCopy - httpstate= Content-Type: application/json 07/30/2015 19:49:56(GMT) - Util::httpCopy - httpstate= Date: Thu, 30 Jul 2015 19:49:55 GMT 07/30/2015 19:49:56(GMT) - Util::httpCopy - httpstate= Connection: close 07/30/2015 19:50:11(GMT) - writeDebugFile - Install Information: 07/30/2015 19:50:11(GMT) - writeDebugFile - Install Version: 6.1.0.00104 07/30/2015 19:50:11(GMT) - writeDebugFile - Install Source : /home/ankit/Downloads/CCS6.1.0.00104_linux 07/30/2015 19:50:11(GMT) - writeDebugFile - Install Temp : /tmp/ccs_c2f139ea-fea9-4ab8-7ce1-7ccfaa965d33 07/30/2015 19:50:11(GMT) - writeDebugFile - Install Type : Offline 07/30/2015 19:50:11(GMT) - writeDebugFile - OS : Linux 07/30/2015 19:50:11(GMT) - writeDebugFile - OS Version : 3.13.0-59-generic 07/30/2015 19:50:11(GMT) - writeDebugFile - OS Platform : unix 07/30/2015 19:50:11(GMT) - writeDebugFile - : 64-bit 07/30/2015 19:50:11(GMT) - writeDebugFile - User ID : root 07/30/2015 19:50:11(GMT) - writeDebugFile - Timezone : IST 07/30/2015 19:50:11(GMT) - writeDebugFile - IPAddress : 127.0.1.1 07/30/2015 19:50:11(GMT) - writeDebugFile - Update/Rerun : 0 07/30/2015 19:50:11(GMT) - writeDebugFile - Command line : installersrc /home/ankit/Downloads/CCS6.1.0.00104_linux installertmp /tmp/ccs_c2f139ea-fea9-4ab8-7ce1-7ccfaa965d33 buildid 6.1.0.00104 installer /home/ankit/Downloads/CCS6.1.0.00104_linux/ccs_setup_6.1.0.00104.bin bitness 64-bit 07/30/2015 19:50:11(GMT) - writeDebugFile - CCS_WARNING: {Failed to locate 32-bit system libraries required for CCS operation: } 07/30/2015 19:50:11(GMT) - writeDebugFile - Product families selected: 07/30/2015 19:50:11(GMT) - writeDebugFile - PF_STELLARIS 07/30/2015 19:50:11(GMT) - writeDebugFile - Components to be installed: 07/30/2015 19:50:11(GMT) - writeDebugFile - EMU_STELLARIS 07/30/2015 19:50:11(GMT) - writeDebugFile - TIVA_STELLARIS_DRIVERS 07/30/2015 19:50:11(GMT) - writeDebugFile - TIVA_TM4C 07/30/2015 19:50:11(GMT) - writeDebugFile - EMU_HERCULES 07/30/2015 19:50:11(GMT) - writeDebugFile - ARM_CGT_HELP 07/30/2015 19:50:11(GMT) - writeDebugFile - CGT_DEFAULTLIBS_TMS470 07/30/2015 19:50:11(GMT) - writeDebugFile - DMED 07/30/2015 19:50:11(GMT) - writeDebugFile - EMU_TI 07/30/2015 19:50:11(GMT) - writeDebugFile - JRE 07/30/2015 19:50:11(GMT) - writeDebugFile - P2APP 07/30/2015 19:50:11(GMT) - writeDebugFile - ECLIPSE 07/30/2015 19:50:11(GMT) - writeDebugFile - ECLIPSECORE 07/30/2015 19:50:11(GMT) - writeDebugFile - P2TOOLS 07/30/2015 19:50:11(GMT) - writeDebugFile - GMF 07/30/2015 19:50:11(GMT) - writeDebugFile - IDE_MAIN 07/30/2015 19:50:11(GMT) - writeDebugFile - IDE_WORKFLOW 07/30/2015 19:50:11(GMT) - writeDebugFile - DVT_COMMON 07/30/2015 19:50:11(GMT) - writeDebugFile - DVT_UIA 07/30/2015 19:50:11(GMT) - writeDebugFile - DVT_VIA_CCS 07/30/2015 19:50:11(GMT) - writeDebugFile - XULRUNNER 07/30/2015 19:50:11(GMT) - writeDebugFile - INSTALLER 07/30/2015 19:50:11(GMT) - writeDebugFile - IDE_CHROME 07/30/2015 19:50:11(GMT) - writeDebugFile - IDE_TOOLS_COMMON 07/30/2015 19:50:11(GMT) - writeDebugFile - IDE_GC 07/30/2015 19:50:11(GMT) - writeDebugFile - TARGET_CONTENT_CORE 07/30/2015 19:50:11(GMT) - writeDebugFile - IDE_ARM 07/30/2015 19:50:11(GMT) - writeDebugFile - DVT_TRACE 07/30/2015 19:50:11(GMT) - writeDebugFile - DS 07/30/2015 19:50:11(GMT) - writeDebugFile - DS_FLASH 07/30/2015 19:50:11(GMT) - writeDebugFile - Apps to be installed when CCS starts up: 07/30/2015 19:50:11(GMT) - getprefix - installdir for ARM_CGT_HELP: /opt/ti/ccsv6/ 07/30/2015 19:50:11(GMT) - getprefix - installdir for C2000_CGT_HELP: /opt/ti/ccsv6/ 07/30/2015 19:50:11(GMT) - getprefix - installdir for C5500_CGT_HELP: /opt/ti/ccsv6/ 07/30/2015 19:50:11(GMT) - getprefix - installdir for C6000_CGT_HELP: /opt/ti/ccsv6/ 07/30/2015 19:50:11(GMT) - getinstalluninstallcmds - Did not find matching component in InstallIni CCS_DOC. Using Defaults. 07/30/2015 19:50:11(GMT) - getinstalluninstallcmds - Did not find matching component in InstallIni CCS_LAUNCHER. Using Defaults. 07/30/2015 19:50:11(GMT) - getinstalluninstallcmds - Did not find matching component in InstallIni CCS_UTILS. Using Defaults. 07/30/2015 19:50:11(GMT) - getprefix - installdir for DVT_COMMON: /opt/ti/ccsv6/ 07/30/2015 19:50:11(GMT) - getprefix - installdir for DVT_ENERGYTRACE: /opt/ti/ccsv6/ 07/30/2015 19:50:11(GMT) - getprefix - installdir for DVT_TRACE: /opt/ti/ccsv6/ 07/30/2015 19:50:11(GMT) - getprefix - installdir for DVT_UIA: /opt/ti/ccsv6/ 07/30/2015 19:50:11(GMT) - getprefix - installdir for DVT_VIA_CCS: /opt/ti/ccsv6/ 07/30/2015 19:50:11(GMT) - getprefix - installdir for ECLIPSE: /opt/ti/ccsv6/ 07/30/2015 19:50:11(GMT) - getprefix - installdir for EMU_SD: /opt/ti/ccsv6/ccs_base 07/30/2015 19:50:11(GMT) - getprefix - installdir for GMF: /opt/ti/ccsv6/ 07/30/2015 19:50:11(GMT) - getprefix - installdir for IDE_ARM: /opt/ti/ccsv6/ 07/30/2015 19:50:11(GMT) - getprefix - installdir for IDE_C2000: /opt/ti/ccsv6/ 07/30/2015 19:50:11(GMT) - getprefix - installdir for IDE_C5500: /opt/ti/ccsv6/ 07/30/2015 19:50:11(GMT) - getprefix - installdir for IDE_C6000: /opt/ti/ccsv6/ 07/30/2015 19:50:11(GMT) - getprefix - installdir for IDE_CHROME: /opt/ti/ccsv6/ 07/30/2015 19:50:11(GMT) - getprefix - installdir for IDE_GC: /opt/ti/ccsv6/ 07/30/2015 19:50:11(GMT) - getprefix - installdir for IDE_MAIN: /opt/ti/ccsv6/ 07/30/2015 19:50:11(GMT) - getprefix - installdir for IDE_MSP430: /opt/ti/ccsv6/ 07/30/2015 19:50:11(GMT) - getprefix - installdir for IDE_TOOLS_COMMON: /opt/ti/ccsv6/ 07/30/2015 19:50:11(GMT) - getprefix - installdir for IDE_WORKFLOW: /opt/ti/ccsv6/ 07/30/2015 19:50:11(GMT) - getprefix - installdir for KEYSTONE1: /opt/ti/ccsv6/ccs_base 07/30/2015 19:50:11(GMT) - getprefix - installdir for KEYSTONE2: /opt/ti/ccsv6/ccs_base 07/30/2015 19:50:11(GMT) - getprefix - installdir for MSP430_CGT_HELP: /opt/ti/ccsv6/ 07/30/2015 19:50:11(GMT) - getprefix - installdir for P2APP: /opt/ti/ccsv6/ 07/30/2015 19:50:11(GMT) - getprefix - installdir for P2TOOLS: /opt/ti/ccsv6/ 07/30/2015 19:50:11(GMT) - getinstalluninstallcmds - Did not find matching component in InstallIni TARGETDB_DEF_PROPS. Using Defaults. 07/30/2015 19:50:11(GMT) - getprefix - installdir for TARGET_CONTENT_CORE: /opt/ti/ccsv6/.. 07/30/2015 19:50:11(GMT) - Util::getProperty - No /opt/ti/ccsv6/eclipse/ccs.properties file found 07/30/2015 19:50:11(GMT) - Util::getProperty - No /opt/ti/ccsv6/eclipse/ccs.properties file found 07/30/2015 19:50:11(GMT) - ProgressPane::Run - non-threaded 07/30/2015 19:50:11(GMT) - ProgressPane::Run - RunInstall /opt/ti/ccsv6/eclipse/ccs_config.xml 0 0 0 0 /opt/ti/ccsv6/install_logs/ccs_setup_6.1.0.00104_install.log ::progressPane0 -1 07/30/2015 19:50:11(GMT) - RunMain - Started with params pConfigFile=/opt/ti/ccsv6/eclipse/ccs_config.xml pProfiling=0 pUpdate=0 logfile=/opt/ti/ccsv6/install_logs/ccs_setup_6.1.0.00104_install.log progress=::progressUpdate0 07/30/2015 19:50:11(GMT) - RunMain - encoding = utf-8 07/30/2015 19:50:11(GMT) - readConfigFile - Start installing components: 07/30/2015 19:50:11(GMT) - readConfigFile - read config file /opt/ti/ccsv6/eclipse/ccs_config.xml 07/30/2015 19:50:11(GMT) - readConfigFile - found /opt/ti/ccsv6/eclipse/ccs_config.xml 07/30/2015 19:50:11(GMT) - readConfigFile - Parsing Root Elements 07/30/2015 19:50:11(GMT) - readConfigFile - Done Parsing 07/30/2015 19:50:11(GMT) - readConfigFile - CCSDIR=/opt/ti/ccsv6 07/30/2015 19:50:11(GMT) - readConfigFile - EclipseDir=/opt/ti/ccsv6/eclipse 07/30/2015 19:50:11(GMT) - readConfigFile - InstallDir=/opt/ti 07/30/2015 19:50:11(GMT) - readConfigFile - TempDir=/tmp/ccs_c2f139ea-fea9-4ab8-7ce1-7ccfaa965d33 07/30/2015 19:50:11(GMT) - readConfigFile - platform=linux 07/30/2015 19:50:11(GMT) - readConfigFile - LocalBaseRepository=/home/ankit/Downloads/CCS6.1.0.00104_linux/baserepo 07/30/2015 19:50:11(GMT) - readConfigFile - baserepourl=/home/ankit/Downloads/CCS6.1.0.00104_linux/baserepo 07/30/2015 19:50:11(GMT) - readConfigFile - featureurl=/home/ankit/Downloads/CCS6.1.0.00104_linux/featurerepo 07/30/2015 19:50:11(GMT) - readConfigFile - LocalRepository_Exists=1 07/30/2015 19:50:11(GMT) - readConfigFile - componentinstaller=false 07/30/2015 19:50:11(GMT) - readConfigFile - eclipseexe=eclipse 07/30/2015 19:50:11(GMT) - readConfigFile - in install components 07/30/2015 19:50:11(GMT) - readUserProfile - userprofile = 07/30/2015 19:50:11(GMT) - downloadIfRequired - deleted /tmp/ccs_c2f139ea-fea9-4ab8-7ce1-7ccfaa965d33/jre_root.gtk.linux.x86_1.7.0.60 07/30/2015 19:50:11(GMT) - downloadIfRequired - copying /home/ankit/Downloads/CCS6.1.0.00104_linux/featurerepo/binary/jre_root.gtk.linux.x86_1.7.0.60 07/30/2015 19:50:11(GMT) - downloadIfRequired - copied /home/ankit/Downloads/CCS6.1.0.00104_linux/featurerepo/binary/jre_root.gtk.linux.x86_1.7.0.60 to /tmp/ccs_c2f139ea-fea9-4ab8-7ce1-7ccfaa965d33/jre_root.gtk.linux.x86_1.7.0.60 07/30/2015 19:50:11(GMT) - downloadIfRequired - File /tmp/ccs_c2f139ea-fea9-4ab8-7ce1-7ccfaa965d33/jre_root.gtk.linux.x86_1.7.0.60 already exists. Not attempting to download 07/30/2015 19:50:11(GMT) - extract - cmd = "unzip" -q -o -d "/tmp/ccs_c2f139ea-fea9-4ab8-7ce1-7ccfaa965d33" "/tmp/ccs_c2f139ea-fea9-4ab8-7ce1-7ccfaa965d33/jre_root.gtk.linux.x86_1.7.0.60" 07/30/2015 19:50:12(GMT) - extract - successfully unzipped /tmp/ccs_c2f139ea-fea9-4ab8-7ce1-7ccfaa965d33/jre_root.gtk.linux.x86_1.7.0.60 07/30/2015 19:50:12(GMT) - extract - cmd = "unzip" -q -o -d "/opt/ti/ccsv6/eclipse" "/tmp/ccs_c2f139ea-fea9-4ab8-7ce1-7ccfaa965d33/downloads/jre_1.7.0_60.zip" 07/30/2015 19:50:16(GMT) - extract - successfully unzipped /tmp/ccs_c2f139ea-fea9-4ab8-7ce1-7ccfaa965d33/downloads/jre_1.7.0_60.zip 07/30/2015 19:50:16(GMT) - downloadIfRequired - File /home/ankit/Downloads/CCS6.1.0.00104_linux/baserepo/eclipse_core_4.3.0.rtm_4_candidate.zip already exists. Not attempting to download 07/30/2015 19:50:16(GMT) - extract - cmd = "unzip" -q -o -d "/tmp/ccs_c2f139ea-fea9-4ab8-7ce1-7ccfaa965d33" "/home/ankit/Downloads/CCS6.1.0.00104_linux/baserepo/eclipse_core_4.3.0.rtm_4_candidate.zip" 07/30/2015 19:50:17(GMT) - extract - successfully unzipped /home/ankit/Downloads/CCS6.1.0.00104_linux/baserepo/eclipse_core_4.3.0.rtm_4_candidate.zip 07/30/2015 19:50:17(GMT) - findLauncher - launcher version = 1.3.0.v20130327-1440 07/30/2015 19:50:17(GMT) - installEclipse - CCS_INFO: eclipse does not exist 07/30/2015 19:50:17(GMT) - installEclipse - using /opt/ti/ccsv6/eclipse/jre/bin/java 07/30/2015 19:50:17(GMT) - installEclipse - "/opt/ti/ccsv6/eclipse/jre/bin/java" -Xmx512m -Dorg.eclipse.ecf.provider.filetransfer.retrieve.readTimeout=30000 -Dorg.eclipse.ecf.provider.filetransfer.retrieve.closeTimeout=10000 -Dsun.net.client.defaultConnectTimeout=10000 -Dsun.net.client.defaultReadTimeout=30000 "-Dosgi.configuration.area=/tmp/ccs_c2f139ea-fea9-4ab8-7ce1-7ccfaa965d33/eclipse/cfg" "-Dosgi.instance.area=/tmp/ccs_c2f139ea-fea9-4ab8-7ce1-7ccfaa965d33/eclipse/ws" -jar "/tmp/ccs_c2f139ea-fea9-4ab8-7ce1-7ccfaa965d33/eclipse/plugins/org.eclipse.equinox.launcher_1.3.0.v20130327-1440.jar" -application org.eclipse.equinox.p2.director -repository "file:/home/ankit/Downloads/CCS6.1.0.00104_linux/baserepo/eclipserepo" -installIU org.eclipse.platform.ide,org.eclipse.help.feature.group,org.eclipse.equinox.p2.discovery.feature.feature.group,org.eclipse.equinox.p2.user.ui.feature.group,org.eclipse.cdt.feature.group,org.eclipse.cdt.debug.ui.memory.feature.group,org.eclipse.tm.terminal.sdk.feature.group,org.eclipse.epp.mpc.feature.group,org.eclipse.egit.feature.group,gnu.io.rxtx.feature.group,org.eclipse.cdt.build.crossgcc.feature.group,org.eclipse.rse.feature.group,org.eclipse.cdt.launch.remote.feature.group -destination "/opt/ti/ccsv6/eclipse/" -profile epp.package.cpp -profileProperties org.eclipse.update.install.features=true -bundlepool "/opt/ti/ccsv6/eclipse/" -p2.os linux -p2.ws gtk -p2.arch x86 -roaming 07/30/2015 19:50:17(GMT) - runEclipseApp - running cmd "/opt/ti/ccsv6/eclipse/jre/bin/java" -Xmx512m -Dorg.eclipse.ecf.provider.filetransfer.retrieve.readTimeout=30000 -Dorg.eclipse.ecf.provider.filetransfer.retrieve.closeTimeout=10000 -Dsun.net.client.defaultConnectTimeout=10000 -Dsun.net.client.defaultReadTimeout=30000 "-Dosgi.configuration.area=/tmp/ccs_c2f139ea-fea9-4ab8-7ce1-7ccfaa965d33/eclipse/cfg" "-Dosgi.instance.area=/tmp/ccs_c2f139ea-fea9-4ab8-7ce1-7ccfaa965d33/eclipse/ws" -jar "/tmp/ccs_c2f139ea-fea9-4ab8-7ce1-7ccfaa965d33/eclipse/plugins/org.eclipse.equinox.launcher_1.3.0.v20130327-1440.jar" -application org.eclipse.equinox.p2.director -repository "file:/home/ankit/Downloads/CCS6.1.0.00104_linux/baserepo/eclipserepo" -installIU org.eclipse.platform.ide,org.eclipse.help.feature.group,org.eclipse.equinox.p2.discovery.feature.feature.group,org.eclipse.equinox.p2.user.ui.feature.group,org.eclipse.cdt.feature.group,org.eclipse.cdt.debug.ui.memory.feature.group,org.eclipse.tm.terminal.sdk.feature.group,org.eclipse.epp.mpc.feature.group,org.eclipse.egit.feature.group,gnu.io.rxtx.feature.group,org.eclipse.cdt.build.crossgcc.feature.group,org.eclipse.rse.feature.group,org.eclipse.cdt.launch.remote.feature.group -destination "/opt/ti/ccsv6/eclipse/" -profile epp.package.cpp -profileProperties org.eclipse.update.install.features=true -bundlepool "/opt/ti/ccsv6/eclipse/" -p2.os linux -p2.ws gtk -p2.arch x86 -roaming 07/30/2015 19:50:54(GMT) - runEclipseApp - FAILED 0: Installing org.eclipse.platform.ide 4.4.1.M20140925-0400. Installing org.eclipse.help.feature.group 2.0.102.v20140925-0400. Installing org.eclipse.equinox.p2.discovery.feature.feature.group 1.0.200.v20140512-1802. Installing org.eclipse.equinox.p2.user.ui.feature.group 2.2.0.v20140911-0143. Installing org.eclipse.cdt.feature.group 8.5.0.201409172108. Installing org.eclipse.cdt.debug.ui.memory.feature.group 8.5.0.201409172108. Installing org.eclipse.tm.terminal.sdk.feature.group 3.3.300.201406060905. Installing org.eclipse.epp.mpc.feature.group 1.3.1.v20140908-1651. Installing org.eclipse.egit.feature.group 3.4.1.201406201815-r. Installing gnu.io.rxtx.feature.group 2.1.7.4_v20071016-7B57e7UAXMAAqGAGf. Installing org.eclipse.cdt.build.crossgcc.feature.group 8.5.0.201409172108. Installing org.eclipse.rse.feature.group 3.5.0.201406091451. Installing org.eclipse.cdt.launch.remote.feature.group 8.5.0.201409172108. # # A fatal error has been detected by the Java Runtime Environment: # # SIGSEGV (0xb) at pc=0xf36931fb, pid=18930, tid=4135934784 # # JRE version: Java(TM) SE Runtime Environment (7.0_60-b19) (build 1.7.0_60-b19) # Java VM: Java HotSpot(TM) Server VM (24.60-b09 mixed mode linux-x86 ) # Problematic frame: # j org.eclipse.equinox.internal.p2.artifact.processing.AbstractBufferingStep.getOutputStream()Ljava/io/OutputStream;+14 # # Failed to write core dump. Core dumps have been disabled. To enable core dumping, try "ulimit -c unlimited" before starting Java again # # An error report file with more information is saved as: # /tmp/ccs_c2f139ea-fea9-4ab8-7ce1-7ccfaa965d33/eclipse/hs_err_pid18930.log Compiled method (c2) 27302 507 org.eclipse.equinox.internal.p2.artifact.processing.AbstractBufferingStep::write (11 bytes) total in heap [0xf373c708,0xf373ccac] = 1444 relocation [0xf373c7d0,0xf373c82c] = 92 main code [0xf373c840,0xf373cae0] = 672 stub code [0xf373cae0,0xf373cafc] = 28 oops [0xf373cafc,0xf373cb10] = 20 scopes data [0xf373cb10,0xf373cbe8] = 216 scopes pcs [0xf373cbe8,0xf373cc78] = 144 dependencies [0xf373cc78,0xf373cc80] = 8 handler table [0xf373cc80,0xf373cc98] = 24 nul chk table [0xf373cc98,0xf373ccac] = 20 # # If you would like to submit a bug report, please visit: # http://bugreport.sun.com/bugreport/crash.jsp # child killed: SIGABRT 07/30/2015 19:50:54(GMT) - runEclipseApp - Running again 07/30/2015 19:51:13(GMT) - runEclipseApp - FAILED 1: Installing org.eclipse.platform.ide 4.4.1.M20140925-0400. Installing org.eclipse.help.feature.group 2.0.102.v20140925-0400. Installing org.eclipse.equinox.p2.discovery.feature.feature.group 1.0.200.v20140512-1802. Installing org.eclipse.equinox.p2.user.ui.feature.group 2.2.0.v20140911-0143. Installing org.eclipse.cdt.feature.group 8.5.0.201409172108. Installing org.eclipse.cdt.debug.ui.memory.feature.group 8.5.0.201409172108. Installing org.eclipse.tm.terminal.sdk.feature.group 3.3.300.201406060905. Installing org.eclipse.epp.mpc.feature.group 1.3.1.v20140908-1651. Installing org.eclipse.egit.feature.group 3.4.1.201406201815-r. Installing gnu.io.rxtx.feature.group 2.1.7.4_v20071016-7B57e7UAXMAAqGAGf. Installing org.eclipse.cdt.build.crossgcc.feature.group 8.5.0.201409172108. Installing org.eclipse.rse.feature.group 3.5.0.201406091451. Installing org.eclipse.cdt.launch.remote.feature.group 8.5.0.201409172108. # # A fatal error has been detected by the Java Runtime Environment: # # SIGSEGV (0xb) at pc=0xf36131fb, pid=19011, tid=4135512896 # # JRE version: Java(TM) SE Runtime Environment (7.0_60-b19) (build 1.7.0_60-b19) # Java VM: Java HotSpot(TM) Server VM (24.60-b09 mixed mode linux-x86 ) # Problematic frame: # j org.eclipse.equinox.internal.p2.artifact.processing.AbstractBufferingStep.getOutputStream()Ljava/io/OutputStream;+14 # # Failed to write core dump. Core dumps have been disabled. To enable core dumping, try "ulimit -c unlimited" before starting Java again # # An error report file with more information is saved as: # /tmp/ccs_c2f139ea-fea9-4ab8-7ce1-7ccfaa965d33/eclipse/hs_err_pid19011.log Compiled method (c2) 9199 494 org.eclipse.equinox.internal.p2.artifact.processing.AbstractBufferingStep::write (11 bytes) total in heap [0xf3699688,0xf3699c2c] = 1444 relocation [0xf3699750,0xf36997ac] = 92 main code [0xf36997c0,0xf3699a60] = 672 stub code [0xf3699a60,0xf3699a7c] = 28 oops [0xf3699a7c,0xf3699a90] = 20 scopes data [0xf3699a90,0xf3699b68] = 216 scopes pcs [0xf3699b68,0xf3699bf8] = 144 dependencies [0xf3699bf8,0xf3699c00] = 8 handler table [0xf3699c00,0xf3699c18] = 24 nul chk table [0xf3699c18,0xf3699c2c] = 20 # # If you would like to submit a bug report, please visit: # http://bugreport.sun.com/bugreport/crash.jsp # Artifact repository out of sync. Overwriting /opt/ti/ccsv6/eclipse/plugins/com.jcraft.jsch_0.1.50.v201403120620.jar 07/30/2015 19:51:13(GMT) - runEclipseApp - Running again 07/30/2015 19:51:33(GMT) - runEclipseApp - FAILED 2: Installing org.eclipse.platform.ide 4.4.1.M20140925-0400. Installing org.eclipse.help.feature.group 2.0.102.v20140925-0400. Installing org.eclipse.equinox.p2.discovery.feature.feature.group 1.0.200.v20140512-1802. Installing org.eclipse.equinox.p2.user.ui.feature.group 2.2.0.v20140911-0143. Installing org.eclipse.cdt.feature.group 8.5.0.201409172108. Installing org.eclipse.cdt.debug.ui.memory.feature.group 8.5.0.201409172108. Installing org.eclipse.tm.terminal.sdk.feature.group 3.3.300.201406060905. Installing org.eclipse.epp.mpc.feature.group 1.3.1.v20140908-1651. Installing org.eclipse.egit.feature.group 3.4.1.201406201815-r. Installing gnu.io.rxtx.feature.group 2.1.7.4_v20071016-7B57e7UAXMAAqGAGf. Installing org.eclipse.cdt.build.crossgcc.feature.group 8.5.0.201409172108. Installing org.eclipse.rse.feature.group 3.5.0.201406091451. Installing org.eclipse.cdt.launch.remote.feature.group 8.5.0.201409172108. # # A fatal error has been detected by the Java Runtime Environment: # # SIGSEGV (0xb) at pc=0xf36061fb, pid=19072, tid=4135340864 # # JRE version: Java(TM) SE Runtime Environment (7.0_60-b19) (build 1.7.0_60-b19) # Java VM: Java HotSpot(TM) Server VM (24.60-b09 mixed mode linux-x86 ) # Problematic frame: # j org.eclipse.equinox.internal.p2.artifact.processing.AbstractBufferingStep.getOutputStream()Ljava/io/OutputStream;+14 # # Failed to write core dump. Core dumps have been disabled. To enable core dumping, try "ulimit -c unlimited" before starting Java again # # An error report file with more information is saved as: # /tmp/ccs_c2f139ea-fea9-4ab8-7ce1-7ccfaa965d33/eclipse/hs_err_pid19072.log Compiled method (c2) 9327 503 org.eclipse.equinox.internal.p2.artifact.processing.AbstractBufferingStep::write (11 bytes) total in heap [0xf374a448,0xf374a9ec] = 1444 relocation [0xf374a510,0xf374a56c] = 92 main code [0xf374a580,0xf374a820] = 672 stub code [0xf374a820,0xf374a83c] = 28 oops [0xf374a83c,0xf374a850] = 20 scopes data [0xf374a850,0xf374a928] = 216 scopes pcs [0xf374a928,0xf374a9b8] = 144 dependencies [0xf374a9b8,0xf374a9c0] = 8 handler table [0xf374a9c0,0xf374a9d8] = 24 nul chk table [0xf374a9d8,0xf374a9ec] = 20 # # If you would like to submit a bug report, please visit: # http://bugreport.sun.com/bugreport/crash.jsp # Artifact repository out of sync. Overwriting /opt/ti/ccsv6/eclipse/plugins/com.sun.el_2.2.0.v201303151357.jar 07/30/2015 19:51:33(GMT) - runEclipseApp - Running again 07/30/2015 19:51:53(GMT) - runEclipseApp - FAILED 3: Installing org.eclipse.platform.ide 4.4.1.M20140925-0400. Installing org.eclipse.help.feature.group 2.0.102.v20140925-0400. Installing org.eclipse.equinox.p2.discovery.feature.feature.group 1.0.200.v20140512-1802. Installing org.eclipse.equinox.p2.user.ui.feature.group 2.2.0.v20140911-0143. Installing org.eclipse.cdt.feature.group 8.5.0.201409172108. Installing org.eclipse.cdt.debug.ui.memory.feature.group 8.5.0.201409172108. Installing org.eclipse.tm.terminal.sdk.feature.group 3.3.300.201406060905. Installing org.eclipse.epp.mpc.feature.group 1.3.1.v20140908-1651. Installing org.eclipse.egit.feature.group 3.4.1.201406201815-r. Installing gnu.io.rxtx.feature.group 2.1.7.4_v20071016-7B57e7UAXMAAqGAGf. Installing org.eclipse.cdt.build.crossgcc.feature.group 8.5.0.201409172108. Installing org.eclipse.rse.feature.group 3.5.0.201406091451. Installing org.eclipse.cdt.launch.remote.feature.group 8.5.0.201409172108. # # A fatal error has been detected by the Java Runtime Environment: # # SIGSEGV (0xb) at pc=0xf36131fb, pid=19129, tid=4135488320 # # JRE version: Java(TM) SE Runtime Environment (7.0_60-b19) (build 1.7.0_60-b19) # Java VM: Java HotSpot(TM) Server VM (24.60-b09 mixed mode linux-x86 ) # Problematic frame: # j org.eclipse.equinox.internal.p2.artifact.processing.AbstractBufferingStep.getOutputStream()Ljava/io/OutputStream;+14 # # Failed to write core dump. Core dumps have been disabled. To enable core dumping, try "ulimit -c unlimited" before starting Java again # # An error report file with more information is saved as: # /tmp/ccs_c2f139ea-fea9-4ab8-7ce1-7ccfaa965d33/eclipse/hs_err_pid19129.log Compiled method (c2) 9724 509 org.eclipse.equinox.internal.p2.artifact.processing.AbstractBufferingStep::write (11 bytes) total in heap [0xf369a5c8,0xf369ab6c] = 1444 relocation [0xf369a690,0xf369a6ec] = 92 main code [0xf369a700,0xf369a9a0] = 672 stub code [0xf369a9a0,0xf369a9bc] = 28 oops [0xf369a9bc,0xf369a9d0] = 20 scopes data [0xf369a9d0,0xf369aaa8] = 216 scopes pcs [0xf369aaa8,0xf369ab38] = 144 dependencies [0xf369ab38,0xf369ab40] = 8 handler table [0xf369ab40,0xf369ab58] = 24 nul chk table [0xf369ab58,0xf369ab6c] = 20 # # If you would like to submit a bug report, please visit: # http://bugreport.sun.com/bugreport/crash.jsp # Artifact repository out of sync. Overwriting /opt/ti/ccsv6/eclipse/plugins/gnu.io.rxtx_2.1.7.4_v20071016.jar 07/30/2015 19:51:53(GMT) - runEclipseApp - Running again 07/30/2015 19:52:12(GMT) - runEclipseApp - FAILED 4: Installing org.eclipse.platform.ide 4.4.1.M20140925-0400. Installing org.eclipse.help.feature.group 2.0.102.v20140925-0400. Installing org.eclipse.equinox.p2.discovery.feature.feature.group 1.0.200.v20140512-1802. Installing org.eclipse.equinox.p2.user.ui.feature.group 2.2.0.v20140911-0143. Installing org.eclipse.cdt.feature.group 8.5.0.201409172108. Installing org.eclipse.cdt.debug.ui.memory.feature.group 8.5.0.201409172108. Installing org.eclipse.tm.terminal.sdk.feature.group 3.3.300.201406060905. Installing org.eclipse.epp.mpc.feature.group 1.3.1.v20140908-1651. Installing org.eclipse.egit.feature.group 3.4.1.201406201815-r. Installing gnu.io.rxtx.feature.group 2.1.7.4_v20071016-7B57e7UAXMAAqGAGf. Installing org.eclipse.cdt.build.crossgcc.feature.group 8.5.0.201409172108. Installing org.eclipse.rse.feature.group 3.5.0.201406091451. Installing org.eclipse.cdt.launch.remote.feature.group 8.5.0.201409172108. # # A fatal error has been detected by the Java Runtime Environment: # # SIGSEGV (0xb) at pc=0xf36061fb, pid=19187, tid=4135385920 # # JRE version: Java(TM) SE Runtime Environment (7.0_60-b19) (build 1.7.0_60-b19) # Java VM: Java HotSpot(TM) Server VM (24.60-b09 mixed mode linux-x86 ) # Problematic frame: # j org.eclipse.equinox.internal.p2.artifact.processing.AbstractBufferingStep.getOutputStream()Ljava/io/OutputStream;+14 # # Failed to write core dump. Core dumps have been disabled. To enable core dumping, try "ulimit -c unlimited" before starting Java again # # An error report file with more information is saved as: # /tmp/ccs_c2f139ea-fea9-4ab8-7ce1-7ccfaa965d33/eclipse/hs_err_pid19187.log Compiled method (c2) 9203 496 org.eclipse.equinox.internal.p2.artifact.processing.AbstractBufferingStep::write (11 bytes) total in heap [0xf36f9b08,0xf36fa0ac] = 1444 relocation [0xf36f9bd0,0xf36f9c2c] = 92 main code [0xf36f9c40,0xf36f9ee0] = 672 stub code [0xf36f9ee0,0xf36f9efc] = 28 oops [0xf36f9efc,0xf36f9f10] = 20 scopes data [0xf36f9f10,0xf36f9fe8] = 216 scopes pcs [0xf36f9fe8,0xf36fa078] = 144 dependencies [0xf36fa078,0xf36fa080] = 8 handler table [0xf36fa080,0xf36fa098] = 24 nul chk table [0xf36fa098,0xf36fa0ac] = 20 # # If you would like to submit a bug report, please visit: # http://bugreport.sun.com/bugreport/crash.jsp # Artifact repository out of sync. Overwriting /opt/ti/ccsv6/eclipse/plugins/javaewah_0.7.9.v201401101600.jar 07/30/2015 19:52:12(GMT) - runEclipseApp - Running again 07/30/2015 19:52:34(GMT) - runEclipseApp - FAILED 5: Installing org.eclipse.platform.ide 4.4.1.M20140925-0400. Installing org.eclipse.help.feature.group 2.0.102.v20140925-0400. Installing org.eclipse.equinox.p2.discovery.feature.feature.group 1.0.200.v20140512-1802. Installing org.eclipse.equinox.p2.user.ui.feature.group 2.2.0.v20140911-0143. Installing org.eclipse.cdt.feature.group 8.5.0.201409172108. Installing org.eclipse.cdt.debug.ui.memory.feature.group 8.5.0.201409172108. Installing org.eclipse.tm.terminal.sdk.feature.group 3.3.300.201406060905. Installing org.eclipse.epp.mpc.feature.group 1.3.1.v20140908-1651. Installing org.eclipse.egit.feature.group 3.4.1.201406201815-r. Installing gnu.io.rxtx.feature.group 2.1.7.4_v20071016-7B57e7UAXMAAqGAGf. Installing org.eclipse.cdt.build.crossgcc.feature.group 8.5.0.201409172108. Installing org.eclipse.rse.feature.group 3.5.0.201406091451. Installing org.eclipse.cdt.launch.remote.feature.group 8.5.0.201409172108. # [thread -849818816 also had an error]# A fatal error has been detected by the Java Runtime Environment: # # SIGSEGV (0xb) at pc=0xf36131fb, pid=19258, tid=4135893824 # # JRE version: Java(TM) SE Runtime Environment (7.0_60-b19) (build 1.7.0_60-b19) # Java VM: Java HotSpot(TM) Server VM (24.60-b09 mixed mode linux-x86 ) # Problematic frame: # j org.eclipse.equinox.internal.p2.artifact.processing.AbstractBufferingStep.getOutputStream()Ljava/io/OutputStream;+14 # # Failed to write core dump. Core dumps have been disabled. To enable core dumping, try "ulimit -c unlimited" before starting Java again # # An error report file with more information is saved as: # /tmp/ccs_c2f139ea-fea9-4ab8-7ce1-7ccfaa965d33/eclipse/hs_err_pid19258.log Compiled method (c2) 11817 512 org.eclipse.equinox.internal.p2.artifact.processing.AbstractBufferingStep::write (11 bytes) total in heap [0xf373e108,0xf373e6ac] = 1444 relocation [0xf373e1d0,0xf373e22c] = 92 main code [0xf373e240,0xf373e4e0] = 672 stub code [0xf373e4e0,0xf373e4fc] = 28 oops [0xf373e4fc,0xf373e510] = 20 scopes data [0xf373e510,0xf373e5e8] = 216 scopes pcs [0xf373e5e8,0xf373e678] = 144 dependencies [0xf373e678,0xf373e680] = 8 handler table [0xf373e680,0xf373e698] = 24 nul chk table [0xf373e698,0xf373e6ac] = 20 # # If you would like to submit a bug report, please visit: # http://bugreport.sun.com/bugreport/crash.jsp # Artifact repository out of sync. Overwriting /opt/ti/ccsv6/eclipse/plugins/javax.annotation_1.2.0.v201401042248.jar 07/30/2015 19:52:34(GMT) - runEclipseApp - Running again 07/30/2015 19:52:58(GMT) - runEclipseApp - FAILED 6: Installing org.eclipse.platform.ide 4.4.1.M20140925-0400. Installing org.eclipse.help.feature.group 2.0.102.v20140925-0400. Installing org.eclipse.equinox.p2.discovery.feature.feature.group 1.0.200.v20140512-1802. Installing org.eclipse.equinox.p2.user.ui.feature.group 2.2.0.v20140911-0143. Installing org.eclipse.cdt.feature.group 8.5.0.201409172108. Installing org.eclipse.cdt.debug.ui.memory.feature.group 8.5.0.201409172108. Installing org.eclipse.tm.terminal.sdk.feature.group 3.3.300.201406060905. Installing org.eclipse.epp.mpc.feature.group 1.3.1.v20140908-1651. Installing org.eclipse.egit.feature.group 3.4.1.201406201815-r. Installing gnu.io.rxtx.feature.group 2.1.7.4_v20071016-7B57e7UAXMAAqGAGf. Installing org.eclipse.cdt.build.crossgcc.feature.group 8.5.0.201409172108. Installing org.eclipse.rse.feature.group 3.5.0.201406091451. Installing org.eclipse.cdt.launch.remote.feature.group 8.5.0.201409172108. # # A fatal error has been detected by the Java Runtime Environment: # # SIGSEGV (0xb) at pc=0xf36131fb, pid=19336, tid=4135713600 # # JRE version: Java(TM) SE Runtime Environment (7.0_60-b19) (build 1.7.0_60-b19) # Java VM: Java HotSpot(TM) Server VM (24.60-b09 mixed mode linux-x86 ) # Problematic frame: # j org.eclipse.equinox.internal.p2.artifact.processing.AbstractBufferingStep.getOutputStream()Ljava/io/OutputStream;+14 # # Failed to write core dump. Core dumps have been disabled. To enable core dumping, try "ulimit -c unlimited" before starting Java again # [thread -850871488 also had an error] # An error report file with more information is saved as: # [thread -850871488 also had an error] Compiled method (c2) 14200 504 org.eclipse.equinox.internal.p2.artifact.processing.AbstractBufferingStep::write (11 bytes) total in heap [0xf3753488,0xf3753a2c] = 1444 relocation [0xf3753550,0xf37535ac] = 92 main code [0xf37535c0,0xf3753860] = 672 stub code [0xf3753860,0xf375387c] = 28 oops [0xf375387c,0xf3753890] = 20 scopes data [0xf3753890,0xf3753968] = 216 scopes pcs [0xf3753968,0xf37539f8] = 144 dependencies [0xf37539f8,0xf3753a00] = 8 handler table [0xf3753a00,0xf3753a18] = 24 nul chk table [0xf3753a18,0xf3753a2c] = 20 # # If you would like to submit a bug report, please visit: # http://bugreport.sun.com/bugreport/crash.jsp # Artifact repository out of sync. Overwriting /opt/ti/ccsv6/eclipse/plugins/javax.el_2.2.0.v201303151357.jar 07/30/2015 19:52:58(GMT) - runEclipseApp - Running again 07/30/2015 19:54:54(GMT) - runEclipseApp - FAILED 7: Installing org.eclipse.platform.ide 4.4.1.M20140925-0400. Installing org.eclipse.help.feature.group 2.0.102.v20140925-0400. Installing org.eclipse.equinox.p2.discovery.feature.feature.group 1.0.200.v20140512-1802. Installing org.eclipse.equinox.p2.user.ui.feature.group 2.2.0.v20140911-0143. Installing org.eclipse.cdt.feature.group 8.5.0.201409172108. Installing org.eclipse.cdt.debug.ui.memory.feature.group 8.5.0.201409172108. Installing org.eclipse.tm.terminal.sdk.feature.group 3.3.300.201406060905. Installing org.eclipse.epp.mpc.feature.group 1.3.1.v20140908-1651. Installing org.eclipse.egit.feature.group 3.4.1.201406201815-r. Installing gnu.io.rxtx.feature.group 2.1.7.4_v20071016-7B57e7UAXMAAqGAGf. Installing org.eclipse.cdt.build.crossgcc.feature.group 8.5.0.201409172108. Installing org.eclipse.rse.feature.group 3.5.0.201406091451. Installing org.eclipse.cdt.launch.remote.feature.group 8.5.0.201409172108. Installation failed. Artifact repository out of sync. Overwriting /opt/ti/ccsv6/eclipse/plugins/javax.inject_1.0.0.v20091030.jar An error occurred while collecting items to be installed session context was:(profile=epp.package.cpp, phase=org.eclipse.equinox.internal.p2.engine.phases.Collect, operand=, action=). Error closing the output stream for org.eclipse.update.feature,org.eclipse.cdt.build.crossgcc,8.5.0.201409172108 on repository file:/opt/ti/ccsv6/eclipse/. Caused by: java.io.IOException: Error unzipping /tmp/org.eclipse.cdt.build.crossgcc_8.5.0.2014091721084652249031031459309.jar: Invalid zip file format Application failed, log file location: /tmp/ccs_c2f139ea-fea9-4ab8-7ce1-7ccfaa965d33/eclipse/cfg/1438285980087.log 07/30/2015 19:54:54(GMT) - runEclipseApp - Running again 07/30/2015 19:55:16(GMT) - runEclipseApp - Installing org.eclipse.platform.ide 4.4.1.M20140925-0400. Installing org.eclipse.help.feature.group 2.0.102.v20140925-0400. Installing org.eclipse.equinox.p2.discovery.feature.feature.group 1.0.200.v20140512-1802. Installing org.eclipse.equinox.p2.user.ui.feature.group 2.2.0.v20140911-0143. Installing org.eclipse.cdt.feature.group 8.5.0.201409172108. Installing org.eclipse.cdt.debug.ui.memory.feature.group 8.5.0.201409172108. Installing org.eclipse.tm.terminal.sdk.feature.group 3.3.300.201406060905. Installing org.eclipse.epp.mpc.feature.group 1.3.1.v20140908-1651. Installing org.eclipse.egit.feature.group 3.4.1.201406201815-r. Installing gnu.io.rxtx.feature.group 2.1.7.4_v20071016-7B57e7UAXMAAqGAGf. Installing org.eclipse.cdt.build.crossgcc.feature.group 8.5.0.201409172108. Installing org.eclipse.rse.feature.group 3.5.0.201406091451. Installing org.eclipse.cdt.launch.remote.feature.group 8.5.0.201409172108. Operation completed in 18849 ms. done. 07/30/2015 19:55:16(GMT) - installEclipse - eclipse installed successfully, looking for binary 07/30/2015 19:55:16(GMT) - downloadIfRequired - File /home/ankit/Downloads/CCS6.1.0.00104_linux/baserepo/updateinstaller.zip already exists. Not attempting to download 07/30/2015 19:55:16(GMT) - extract - cmd = "unzip" -q -o -d "/opt/ti/ccsv6/eclipse" "/home/ankit/Downloads/CCS6.1.0.00104_linux/baserepo/updateinstaller.zip" 07/30/2015 19:55:16(GMT) - extract - successfully unzipped /home/ankit/Downloads/CCS6.1.0.00104_linux/baserepo/updateinstaller.zip 07/30/2015 19:55:16(GMT) - installP2app - "/opt/ti/ccsv6/eclipse/eclipse" -application org.eclipse.equinox.p2.director -repository "file:/home/ankit/Downloads/CCS6.1.0.00104_linux/baserepo/p2appfRepo" -installiu com.ti.ccstudio.p2appf.feature.group -nosplash 07/30/2015 19:55:16(GMT) - runEclipseApp - running cmd "/opt/ti/ccsv6/eclipse/eclipse" -application org.eclipse.equinox.p2.director -repository "file:/home/ankit/Downloads/CCS6.1.0.00104_linux/baserepo/p2appfRepo" -installiu com.ti.ccstudio.p2appf.feature.group -nosplash 07/30/2015 19:55:26(GMT) - runEclipseApp - FAILED 0: couldn't execute "/opt/ti/ccsv6/eclipse/eclipse": permission denied 07/30/2015 19:55:26(GMT) - runEclipseApp - Running again 07/30/2015 19:55:36(GMT) - runEclipseApp - FAILED 1: couldn't execute "/opt/ti/ccsv6/eclipse/eclipse": permission denied 07/30/2015 19:55:36(GMT) - runEclipseApp - Running again 07/30/2015 19:55:46(GMT) - runEclipseApp - FAILED 2: couldn't execute "/opt/ti/ccsv6/eclipse/eclipse": permission denied 07/30/2015 19:55:46(GMT) - runEclipseApp - Running again 07/30/2015 19:55:56(GMT) - runEclipseApp - FAILED 3: couldn't execute "/opt/ti/ccsv6/eclipse/eclipse": permission denied 07/30/2015 19:55:56(GMT) - runEclipseApp - Running again 07/30/2015 19:56:06(GMT) - runEclipseApp - FAILED 4: couldn't execute "/opt/ti/ccsv6/eclipse/eclipse": permission denied 07/30/2015 19:56:06(GMT) - runEclipseApp - Running again 07/30/2015 19:56:16(GMT) - runEclipseApp - FAILED 5: couldn't execute "/opt/ti/ccsv6/eclipse/eclipse": permission denied 07/30/2015 19:56:16(GMT) - runEclipseApp - Running again 07/30/2015 19:56:26(GMT) - runEclipseApp - FAILED 6: couldn't execute "/opt/ti/ccsv6/eclipse/eclipse": permission denied 07/30/2015 19:56:26(GMT) - runEclipseApp - Running again 07/30/2015 19:56:36(GMT) - runEclipseApp - FAILED 7: couldn't execute "/opt/ti/ccsv6/eclipse/eclipse": permission denied 07/30/2015 19:56:36(GMT) - runEclipseApp - Running again 07/30/2015 19:56:46(GMT) - runEclipseApp - FAILED 8: couldn't execute "/opt/ti/ccsv6/eclipse/eclipse": permission denied 07/30/2015 19:56:46(GMT) - runEclipseApp - Running again 07/30/2015 19:56:56(GMT) - runEclipseApp - FAILED 9: couldn't execute "/opt/ti/ccsv6/eclipse/eclipse": permission denied 07/30/2015 19:56:56(GMT) - runEclipseApp - Running again 07/30/2015 19:57:06(GMT) - runEclipseApp - FAILED 10: couldn't execute "/opt/ti/ccsv6/eclipse/eclipse": permission denied 07/30/2015 19:57:06(GMT) - runEclipseApp - Running again 07/30/2015 19:57:16(GMT) - runEclipseApp - FAILED 11: couldn't execute "/opt/ti/ccsv6/eclipse/eclipse": permission denied 07/30/2015 19:57:16(GMT) - runEclipseApp - Running again 07/30/2015 19:57:26(GMT) - runEclipseApp - FAILED 12: couldn't execute "/opt/ti/ccsv6/eclipse/eclipse": permission denied 07/30/2015 19:57:26(GMT) - runEclipseApp - Running again 07/30/2015 19:57:36(GMT) - runEclipseApp - FAILED 13: couldn't execute "/opt/ti/ccsv6/eclipse/eclipse": permission denied 07/30/2015 19:57:36(GMT) - runEclipseApp - Running again 07/30/2015 19:57:46(GMT) - runEclipseApp - FAILED 14: couldn't execute "/opt/ti/ccsv6/eclipse/eclipse": permission denied 07/30/2015 19:57:46(GMT) - runEclipseApp - Running again 07/30/2015 19:57:56(GMT) - runEclipseApp - FAILED 15: couldn't execute "/opt/ti/ccsv6/eclipse/eclipse": permission denied 07/30/2015 19:57:56(GMT) - runEclipseApp - Running again 07/30/2015 19:58:06(GMT) - runEclipseApp - FAILED 16: couldn't execute "/opt/ti/ccsv6/eclipse/eclipse": permission denied 07/30/2015 19:58:06(GMT) - runEclipseApp - Running again 07/30/2015 19:58:16(GMT) - runEclipseApp - FAILED 17: couldn't execute "/opt/ti/ccsv6/eclipse/eclipse": permission denied 07/30/2015 19:58:16(GMT) - runEclipseApp - Running again 07/30/2015 19:58:26(GMT) - runEclipseApp - FAILED 18: couldn't execute "/opt/ti/ccsv6/eclipse/eclipse": permission denied 07/30/2015 19:58:26(GMT) - runEclipseApp - Running again 07/30/2015 19:58:36(GMT) - runEclipseApp - FAILED 19: couldn't execute "/opt/ti/ccsv6/eclipse/eclipse": permission denied 07/30/2015 19:58:36(GMT) - runEclipseApp - Running again 07/30/2015 19:58:36(GMT) - runEclipseApp - FAILED 20: couldn't execute "/opt/ti/ccsv6/eclipse/eclipse": permission denied 07/30/2015 19:58:36(GMT) - runEclipseApp - Can't run again. 07/30/2015 19:58:36(GMT) - processOtherFeatures - length of features = 68; 1; 0 07/30/2015 19:58:36(GMT) - processOtherFeatures - JRE state: feature installed; does not need to be processed 07/30/2015 19:58:36(GMT) - processOtherFeatures - length of features = 68; 2; 0 07/30/2015 19:58:36(GMT) - processOtherFeatures - ECLIPSECORE state: feature installed; does not need to be processed 07/30/2015 19:58:36(GMT) - processOtherFeatures - length of features = 68; 3; 0 07/30/2015 19:58:36(GMT) - processOtherFeatures - processing INSTALLER 07/30/2015 19:58:36(GMT) - processOtherFeatures - state:initial 07/30/2015 19:58:36(GMT) - processOtherFeatures - binary:6.1.0.00104.zip 07/30/2015 19:58:36(GMT) - processOtherFeatures - location = /home/ankit/Downloads/CCS6.1.0.00104_linux/featurerepo 07/30/2015 19:58:36(GMT) - processOtherFeatures - newloc:file:/home/ankit/Downloads/CCS6.1.0.00104_linux/featurerepo 07/30/2015 19:58:36(GMT) - processOtherFeatures - length of features = 68; 4; 1 07/30/2015 19:58:36(GMT) - processOtherFeatures - ECLIPSE state: feature installed; does not need to be processed 07/30/2015 19:58:36(GMT) - processOtherFeatures - length of features = 68; 5; 1 07/30/2015 19:58:36(GMT) - processOtherFeatures - processing DS 07/30/2015 19:58:36(GMT) - processOtherFeatures - state:initial 07/30/2015 19:58:36(GMT) - processOtherFeatures - binary:ti_dspack_ibsetup_6.1.0.1150.bin 07/30/2015 19:58:36(GMT) - processOtherFeatures - location = /home/ankit/Downloads/CCS6.1.0.00104_linux/featurerepo 07/30/2015 19:58:36(GMT) - processOtherFeatures - newloc:file:/home/ankit/Downloads/CCS6.1.0.00104_linux/featurerepo 07/30/2015 19:58:36(GMT) - processOtherFeatures - counting = 6; 5 68 07/30/2015 19:58:36(GMT) - processOtherFeatures - fullrepolist file:/home/ankit/Downloads/CCS6.1.0.00104_linux/featurerepo 07/30/2015 19:58:36(GMT) - processOtherFeatures - fullfeaturelist com.ti.ccstudio.installer.linux.feature.group,com.ti.ccstudio.debugserver.linux.feature.group 07/30/2015 19:58:36(GMT) - runEclipseApp - running cmd "/opt/ti/ccsv6/eclipse/eclipse" -application org.eclipse.equinox.p2.director -repository "file:/home/ankit/Downloads/CCS6.1.0.00104_linux/featurerepo" -installiu com.ti.ccstudio.installer.linux.feature.group,com.ti.ccstudio.debugserver.linux.feature.group -nosplash 07/30/2015 19:58:46(GMT) - runEclipseApp - FAILED 0: couldn't execute "/opt/ti/ccsv6/eclipse/eclipse": permission denied 07/30/2015 19:58:46(GMT) - runEclipseApp - Running again 07/30/2015 19:58:56(GMT) - runEclipseApp - FAILED 1: couldn't execute "/opt/ti/ccsv6/eclipse/eclipse": permission denied 07/30/2015 19:58:56(GMT) - runEclipseApp - Running again 07/30/2015 19:59:06(GMT) - runEclipseApp - FAILED 2: couldn't execute "/opt/ti/ccsv6/eclipse/eclipse": permission denied 07/30/2015 19:59:06(GMT) - runEclipseApp - Running again 07/30/2015 19:59:16(GMT) - runEclipseApp - FAILED 3: couldn't execute "/opt/ti/ccsv6/eclipse/eclipse": permission denied 07/30/2015 19:59:16(GMT) - runEclipseApp - Running again 07/30/2015 19:59:26(GMT) - runEclipseApp - FAILED 4: couldn't execute "/opt/ti/ccsv6/eclipse/eclipse": permission denied 07/30/2015 19:59:26(GMT) - runEclipseApp - Running again 07/30/2015 19:59:36(GMT) - runEclipseApp - FAILED 5: couldn't execute "/opt/ti/ccsv6/eclipse/eclipse": permission denied 07/30/2015 19:59:36(GMT) - runEclipseApp - Running again 07/30/2015 19:59:47(GMT) - runEclipseApp - FAILED 6: couldn't execute "/opt/ti/ccsv6/eclipse/eclipse": permission denied 07/30/2015 19:59:47(GMT) - runEclipseApp - Running again 07/30/2015 19:59:57(GMT) - runEclipseApp - FAILED 7: couldn't execute "/opt/ti/ccsv6/eclipse/eclipse": permission denied 07/30/2015 19:59:57(GMT) - runEclipseApp - Running again 07/30/2015 20:00:07(GMT) - runEclipseApp - FAILED 8: couldn't execute "/opt/ti/ccsv6/eclipse/eclipse": permission denied 07/30/2015 20:00:07(GMT) - runEclipseApp - Running again 07/30/2015 20:00:17(GMT) - runEclipseApp - FAILED 9: couldn't execute "/opt/ti/ccsv6/eclipse/eclipse": permission denied 07/30/2015 20:00:17(GMT) - runEclipseApp - Running again 07/30/2015 20:00:27(GMT) - runEclipseApp - FAILED 10: couldn't execute "/opt/ti/ccsv6/eclipse/eclipse": permission denied 07/30/2015 20:00:27(GMT) - runEclipseApp - Running again 07/30/2015 20:00:37(GMT) - runEclipseApp - FAILED 11: couldn't execute "/opt/ti/ccsv6/eclipse/eclipse": permission denied 07/30/2015 20:00:37(GMT) - runEclipseApp - Running again 07/30/2015 20:00:47(GMT) - runEclipseApp - FAILED 12: couldn't execute "/opt/ti/ccsv6/eclipse/eclipse": permission denied 07/30/2015 20:00:47(GMT) - runEclipseApp - Running again 07/30/2015 20:00:57(GMT) - runEclipseApp - FAILED 13: couldn't execute "/opt/ti/ccsv6/eclipse/eclipse": permission denied 07/30/2015 20:00:57(GMT) - runEclipseApp - Running again 07/30/2015 20:01:07(GMT) - runEclipseApp - FAILED 14: couldn't execute "/opt/ti/ccsv6/eclipse/eclipse": permission denied 07/30/2015 20:01:07(GMT) - runEclipseApp - Running again 07/30/2015 20:01:17(GMT) - runEclipseApp - FAILED 15: couldn't execute "/opt/ti/ccsv6/eclipse/eclipse": permission denied 07/30/2015 20:01:17(GMT) - runEclipseApp - Running again 07/30/2015 20:01:27(GMT) - runEclipseApp - FAILED 16: couldn't execute "/opt/ti/ccsv6/eclipse/eclipse": permission denied 07/30/2015 20:01:27(GMT) - runEclipseApp - Running again 07/30/2015 20:01:37(GMT) - runEclipseApp - FAILED 17: couldn't execute "/opt/ti/ccsv6/eclipse/eclipse": permission denied 07/30/2015 20:01:37(GMT) - runEclipseApp - Running again 07/30/2015 20:01:47(GMT) - runEclipseApp - FAILED 18: couldn't execute "/opt/ti/ccsv6/eclipse/eclipse": permission denied 07/30/2015 20:01:47(GMT) - runEclipseApp - Running again 07/30/2015 20:01:57(GMT) - runEclipseApp - FAILED 19: couldn't execute "/opt/ti/ccsv6/eclipse/eclipse": permission denied 07/30/2015 20:01:57(GMT) - runEclipseApp - Running again 07/30/2015 20:01:57(GMT) - runEclipseApp - FAILED 20: couldn't execute "/opt/ti/ccsv6/eclipse/eclipse": permission denied 07/30/2015 20:01:57(GMT) - runEclipseApp - Can't run again. 07/30/2015 20:01:57(GMT) - processOtherFeatures - Processing INSTALLER to install 07/30/2015 20:01:57(GMT) - processOtherFeatures - current state = initial 07/30/2015 20:01:57(GMT) - processOtherFeatures - location = /home/ankit/Downloads/CCS6.1.0.00104_linux/featurerepo 07/30/2015 20:01:57(GMT) - processOtherFeatures - Binary=/opt/ti/ccsv6/eclipse/downloads/6.1.0.00104.zip 07/30/2015 20:01:57(GMT) - runEclipseApp - running cmd "/opt/ti/ccsv6/eclipse/eclipse" -application org.eclipse.equinox.p2.director -uninstallIU com.ti.ccstudio.installer.linux.feature.group -nosplash 07/30/2015 20:02:07(GMT) - runEclipseApp - FAILED 0: couldn't execute "/opt/ti/ccsv6/eclipse/eclipse": permission denied 07/30/2015 20:02:07(GMT) - runEclipseApp - Running again 07/30/2015 20:02:17(GMT) - runEclipseApp - FAILED 1: couldn't execute "/opt/ti/ccsv6/eclipse/eclipse": permission denied 07/30/2015 20:02:17(GMT) - runEclipseApp - Running again 07/30/2015 20:02:27(GMT) - runEclipseApp - FAILED 2: couldn't execute "/opt/ti/ccsv6/eclipse/eclipse": permission denied 07/30/2015 20:02:27(GMT) - runEclipseApp - Running again 07/30/2015 20:02:37(GMT) - runEclipseApp - FAILED 3: couldn't execute "/opt/ti/ccsv6/eclipse/eclipse": permission denied 07/30/2015 20:02:37(GMT) - runEclipseApp - Running again 07/30/2015 20:02:47(GMT) - runEclipseApp - FAILED 4: couldn't execute "/opt/ti/ccsv6/eclipse/eclipse": permission denied 07/30/2015 20:02:47(GMT) - runEclipseApp - Running again 07/30/2015 20:02:57(GMT) - runEclipseApp - FAILED 5: couldn't execute "/opt/ti/ccsv6/eclipse/eclipse": permission denied 07/30/2015 20:02:57(GMT) - runEclipseApp - Running again 07/30/2015 20:03:07(GMT) - runEclipseApp - FAILED 6: couldn't execute "/opt/ti/ccsv6/eclipse/eclipse": permission denied 07/30/2015 20:03:07(GMT) - runEclipseApp - Running again 07/30/2015 20:03:17(GMT) - runEclipseApp - FAILED 7: couldn't execute "/opt/ti/ccsv6/eclipse/eclipse": permission denied 07/30/2015 20:03:17(GMT) - runEclipseApp - Running again 07/30/2015 20:03:27(GMT) - runEclipseApp - FAILED 8: couldn't execute "/opt/ti/ccsv6/eclipse/eclipse": permission denied 07/30/2015 20:03:27(GMT) - runEclipseApp - Running again 07/30/2015 20:03:37(GMT) - runEclipseApp - FAILED 9: couldn't execute "/opt/ti/ccsv6/eclipse/eclipse": permission denied 07/30/2015 20:03:37(GMT) - runEclipseApp - Running again 07/30/2015 20:03:47(GMT) - runEclipseApp - FAILED 10: couldn't execute "/opt/ti/ccsv6/eclipse/eclipse": permission denied 07/30/2015 20:03:47(GMT) - runEclipseApp - Running again 07/30/2015 20:03:57(GMT) - runEclipseApp - FAILED 11: couldn't execute "/opt/ti/ccsv6/eclipse/eclipse": permission denied 07/30/2015 20:03:57(GMT) - runEclipseApp - Running again 07/30/2015 20:04:07(GMT) - runEclipseApp - FAILED 12: couldn't execute "/opt/ti/ccsv6/eclipse/eclipse": permission denied 07/30/2015 20:04:07(GMT) - runEclipseApp - Running again 07/30/2015 20:04:17(GMT) - runEclipseApp - FAILED 13: couldn't execute "/opt/ti/ccsv6/eclipse/eclipse": permission denied 07/30/2015 20:04:17(GMT) - runEclipseApp - Running again 07/30/2015 20:04:27(GMT) - runEclipseApp - FAILED 14: couldn't execute "/opt/ti/ccsv6/eclipse/eclipse": permission denied 07/30/2015 20:04:27(GMT) - runEclipseApp - Running again 07/30/2015 20:04:37(GMT) - runEclipseApp - FAILED 15: couldn't execute "/opt/ti/ccsv6/eclipse/eclipse": permission denied 07/30/2015 20:04:37(GMT) - runEclipseApp - Running again 07/30/2015 20:04:47(GMT) - runEclipseApp - FAILED 16: couldn't execute "/opt/ti/ccsv6/eclipse/eclipse": permission denied 07/30/2015 20:04:47(GMT) - runEclipseApp - Running again 07/30/2015 20:04:57(GMT) - runEclipseApp - FAILED 17: couldn't execute "/opt/ti/ccsv6/eclipse/eclipse": permission denied 07/30/2015 20:04:57(GMT) - runEclipseApp - Running again 07/30/2015 20:05:07(GMT) - runEclipseApp - FAILED 18: couldn't execute "/opt/ti/ccsv6/eclipse/eclipse": permission denied 07/30/2015 20:05:07(GMT) - runEclipseApp - Running again 07/30/2015 20:05:17(GMT) - runEclipseApp - FAILED 19: couldn't execute "/opt/ti/ccsv6/eclipse/eclipse": permission denied 07/30/2015 20:05:17(GMT) - runEclipseApp - Running again 07/30/2015 20:05:17(GMT) - runEclipseApp - FAILED 20: couldn't execute "/opt/ti/ccsv6/eclipse/eclipse": permission denied 07/30/2015 20:05:17(GMT) - runEclipseApp - Can't run again. 07/30/2015 20:05:17(GMT) - runEclipseApp - running cmd "/opt/ti/ccsv6/eclipse/eclipse" -application org.eclipse.equinox.p2.director -repository "file:/home/ankit/Downloads/CCS6.1.0.00104_linux/featurerepo" -installIU com.ti.ccstudio.installer.linux.feature.group -nosplash 07/30/2015 20:05:27(GMT) - runEclipseApp - FAILED 0: couldn't execute "/opt/ti/ccsv6/eclipse/eclipse": permission denied 07/30/2015 20:05:27(GMT) - runEclipseApp - Running again 07/30/2015 20:05:37(GMT) - runEclipseApp - FAILED 1: couldn't execute "/opt/ti/ccsv6/eclipse/eclipse": permission denied 07/30/2015 20:05:37(GMT) - runEclipseApp - Running again 07/30/2015 20:05:47(GMT) - runEclipseApp - FAILED 2: couldn't execute "/opt/ti/ccsv6/eclipse/eclipse": permission denied 07/30/2015 20:05:47(GMT) - runEclipseApp - Running again 07/30/2015 20:05:57(GMT) - runEclipseApp - FAILED 3: couldn't execute "/opt/ti/ccsv6/eclipse/eclipse": permission denied 07/30/2015 20:05:57(GMT) - runEclipseApp - Running again 07/30/2015 20:06:07(GMT) - runEclipseApp - FAILED 4: couldn't execute "/opt/ti/ccsv6/eclipse/eclipse": permission denied 07/30/2015 20:06:07(GMT) - runEclipseApp - Running again 07/30/2015 20:06:17(GMT) - runEclipseApp - FAILED 5: couldn't execute "/opt/ti/ccsv6/eclipse/eclipse": permission denied 07/30/2015 20:06:17(GMT) - runEclipseApp - Running again 07/30/2015 20:06:27(GMT) - runEclipseApp - FAILED 6: couldn't execute "/opt/ti/ccsv6/eclipse/eclipse": permission denied 07/30/2015 20:06:27(GMT) - runEclipseApp - Running again 07/30/2015 20:06:37(GMT) - runEclipseApp - FAILED 7: couldn't execute "/opt/ti/ccsv6/eclipse/eclipse": permission denied 07/30/2015 20:06:37(GMT) - runEclipseApp - Running again 07/30/2015 20:06:47(GMT) - runEclipseApp - FAILED 8: couldn't execute "/opt/ti/ccsv6/eclipse/eclipse": permission denied 07/30/2015 20:06:47(GMT) - runEclipseApp - Running again 07/30/2015 20:06:57(GMT) - runEclipseApp - FAILED 9: couldn't execute "/opt/ti/ccsv6/eclipse/eclipse": permission denied 07/30/2015 20:06:57(GMT) - runEclipseApp - Running again 07/30/2015 20:07:07(GMT) - runEclipseApp - FAILED 10: couldn't execute "/opt/ti/ccsv6/eclipse/eclipse": permission denied 07/30/2015 20:07:07(GMT) - runEclipseApp - Running again 07/30/2015 20:07:17(GMT) - runEclipseApp - FAILED 11: couldn't execute "/opt/ti/ccsv6/eclipse/eclipse": permission denied 07/30/2015 20:07:17(GMT) - runEclipseApp - Running again 07/30/2015 20:07:27(GMT) - runEclipseApp - FAILED 12: couldn't execute "/opt/ti/ccsv6/eclipse/eclipse": permission denied 07/30/2015 20:07:27(GMT) - runEclipseApp - Running again 07/30/2015 20:07:37(GMT) - runEclipseApp - FAILED 13: couldn't execute "/opt/ti/ccsv6/eclipse/eclipse": permission denied 07/30/2015 20:07:37(GMT) - runEclipseApp - Running again 07/30/2015 20:07:47(GMT) - runEclipseApp - FAILED 14: couldn't execute "/opt/ti/ccsv6/eclipse/eclipse": permission denied 07/30/2015 20:07:47(GMT) - runEclipseApp - Running again 07/30/2015 20:07:57(GMT) - runEclipseApp - FAILED 15: couldn't execute "/opt/ti/ccsv6/eclipse/eclipse": permission denied 07/30/2015 20:07:57(GMT) - runEclipseApp - Running again 07/30/2015 20:08:07(GMT) - runEclipseApp - FAILED 16: couldn't execute "/opt/ti/ccsv6/eclipse/eclipse": permission denied 07/30/2015 20:08:07(GMT) - runEclipseApp - Running again 07/30/2015 20:08:17(GMT) - runEclipseApp - FAILED 17: couldn't execute "/opt/ti/ccsv6/eclipse/eclipse": permission denied 07/30/2015 20:08:17(GMT) - runEclipseApp - Running again 07/30/2015 20:08:27(GMT) - runEclipseApp - FAILED 18: couldn't execute "/opt/ti/ccsv6/eclipse/eclipse": permission denied 07/30/2015 20:08:27(GMT) - runEclipseApp - Running again 07/30/2015 20:08:37(GMT) - runEclipseApp - FAILED 19: couldn't execute "/opt/ti/ccsv6/eclipse/eclipse": permission denied 07/30/2015 20:08:37(GMT) - runEclipseApp - Running again 07/30/2015 20:08:37(GMT) - runEclipseApp - FAILED 20: couldn't execute "/opt/ti/ccsv6/eclipse/eclipse": permission denied 07/30/2015 20:08:37(GMT) - runEclipseApp - Can't run again. 07/30/2015 20:08:37(GMT) - processOtherFeatures - 6.1.0.00104.zip does not exist at /opt/ti/ccsv6/eclipse/downloads/6.1.0.00104.zip. Setting state to feature downloaded 07/30/2015 20:08:37(GMT) - processOtherFeatures - new state: feature downloaded 07/30/2015 20:08:37(GMT) - checkStatus - CCS_ERROR: Installer failed to install com.ti.ccstudio.installer.linux correctly. Please submit these logs to TI for analysis using the next dialog. You may also visit the TI Online CCS support form for additional help. The install logs are located in: /opt/ti/ccsv6/install_logs. 07/30/2015 20:08:37(GMT) - checkStatus - file does not exist /tmp/ccs_c2f139ea-fea9-4ab8-7ce1-7ccfaa965d33/eclipse/ws/.metadata/.log 07/30/2015 20:08:37(GMT) - checkStatus - saving /opt/ti/ccsv6/install_logs 07/30/2015 20:08:37(GMT) - checkStatus - saving /opt/ti/ccsv6/install_logs_20150731012011 07/30/2015 20:08:38(GMT) - checkStatus - CCS_ERROR: Code Composer Studio v6 installation failed.
