I am getting Errors while transfering 3.3 Projects to 6.6.1.00022 Project.I am getting the following Errors.I cannot understand These Errors.
Description Resource Path Location Type
[E1500] file access error: failed to open "Z:/Servo3_IQMATH/F2806/26_FOC_servo3_4-pole_new_motor/Debug/2808init.obj" for writing 2808init.asm /empty/Debug C/C++ Problem
[E1500] file access error: failed to open "Z:/Servo3_IQMATH/F2806/26_FOC_servo3_4-pole_new_motor/Debug/DSP280x_CodeStartBranch.obj" for writing DSP280x_CodeStartBranch.asm /empty line 1601712184 C/C++ Problem
[E1500] file access error: failed to open "Z:/Servo3_IQMATH/F2806/26_FOC_servo3_4-pole_new_motor/Debug/DSP280x_GlobalVariableDefs.obj" for writing DSP280x_GlobalVariableDefs.asm /empty/Debug C/C++ Problem
[E1500] file access error: failed to open "Z:/Servo3_IQMATH/F2806/26_FOC_servo3_4-pole_new_motor/Debug/empty.obj" for writing empty.asm /empty/Debug C/C++ Problem
[E1500] file access error: failed to open "Z:/Servo3_IQMATH/F2806/26_FOC_servo3_4-pole_new_motor/Debug/fir_vel1.obj" for writing fir_vel1.asm /empty C/C++ Problem
[E1500] file access error: failed to open "Z:/Servo3_IQMATH/F2806/26_FOC_servo3_4-pole_new_motor/Debug/password.obj" for writing password.asm /empty line 5870676 C/C++ Problem
<a href="file:/c:/ti/ccsv6/tools/compiler/dmed/HTML/225.html">#225-D</a> function "_nop" declared implicitly empty.c /empty line 239 C/C++ Problem
<a href="file:/c:/ti/ccsv6/tools/compiler/dmed/HTML/225.html">#225-D</a> function "fir_vel1_init" declared implicitly empty.c /empty line 56 C/C++ Problem
<a href="file:/c:/ti/ccsv6/tools/compiler/dmed/HTML/225.html">#225-D</a> function "fir_vel1" declared implicitly empty.c /empty line 271 C/C++ Problem
<a href="file:/c:/ti/ccsv6/tools/compiler/dmed/HTML/225.html">#225-D</a> function "init_spic" declared implicitly empty.c /empty line 55 C/C++ Problem
Build variable 'XDAIS_CG_ROOT' cannot be resolved. empty properties Problems
Invalid project path: Include path not found (\packages\ti\xdais). empty pathentry Path Entry Problem
Invalid project path: Include path not found (D:\Middex\projects\Servo3_IQMATH\DSP280x_common\include). empty pathentry Path Entry Problem
Invalid project path: Include path not found (D:\Middex\projects\Servo3_IQMATH\DSP280x_headers\include). empty pathentry Path Entry Problem
Invalid project path: Include path not found (D:\Middex\projects\Servo3_IQMATH\F2806\2808eZdspUSBTest). empty pathentry Path Entry Problem
Invalid project path: Include path not found (D:\Middex\projects\Servo3_IQMATH\F2806\DSP280x_common\include). empty pathentry Path Entry Problem
Invalid project path: Include path not found (D:\Middex\projects\Servo3_IQMATH\F2806\DSP280x_headers\include). empty pathentry Path Entry Problem
Invalid project path: Include path not found (D:\Middex\projects\Servo3_IQMATH\F2806\include). empty pathentry Path Entry Problem
The Project log file is as follows.
!CONFIGURATION: 'com.ti.ccstudio.buildDefinitions.C2000.Release.2039487239' [Sun Nov 29 11:32:47 CET 2015]
!TOOL: 'com.ti.ccstudio.buildDefinitions.C2000_6.4.exe.compilerRelease.1959985639'
!WARNING: Unresolved option: com.ti.ccstudio.buildDefinitions.C2000_6.4.exe.compilerRelease.1959985639::!--symdebug:dwarf
