I am attempting to launch the CCS IDE from the debug server session using:
ccsServer = env.getServer('CCSServer.1');
ccsSession = ccsServer.openSession(
However, when the CCS IDE launches, it opens with errors about missing plugins or packages. In addition when I close the CCS IDE with the "X" in the upper right-hand corner, it kills the entire JVM, including the application I used to launch the IDE.
I am looking for documentation resources so I can have a better understanding of the IDE launch, and do some more debugging regarding what's going on with the CCSStudio scripting.
These are the errors I am seeing from my Java Application when I call ccsServer.openSession('.*')
logConfig DOES NOT exist
-------Setting DVTLogLevel to: INFO
java.lang.NoClassDefFoundError: com/ti/debug/engine/cce/IDebugEngine$IFactory
at com.ti.ccstudio.debug.server.factory.LicenseEngineFactory.createInstance(LicenseEngineFactory.java:14)
at com.ti.ccstudio.update.CCEUpdateStartup.heartbeat(CCEUpdateStartup.java:34)
at com.ti.ccstudio.update.CCEUpdateStartup.earlyStartup(CCEUpdateStartup.java:13)
at org.eclipse.ui.internal.EarlyStartupRunnable.runEarlyStartup(EarlyStartupRunnable.java:87)
at org.eclipse.ui.internal.EarlyStartupRunnable.run(EarlyStartupRunnable.java:66)
at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:37)
at org.eclipse.ui.internal.Workbench$20.run(Workbench.java:1759)!SESSION 2010-12-16 15:27:31.091 -----------------------------------------------
eclipse.buildId=4.2.0.07000
java.version=1.6.0_17
java.vendor=Sun Microsystems Inc.
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=en_US
Framework arguments: .*
Command-line arguments: .*
This is a continuation of log file C:\MATLAB_Work\Sandbox\CCS_Eclipse_Workspace\.metadata\.bak_0.log
Created Time: 2010-12-16 15:27:42.712
!ENTRY org.eclipse.equinox.registry 4 1 2010-12-16 15:27:42.712
!MESSAGE Plug-in com.ti.ccstudio.project.ui was unable to load class com.ti.ccstudio.project.ui.decorations.ActiveTargetConfigurationDelegate.
!STACK 0
java.lang.NoClassDefFoundError: com/ti/ccstudio/debug/core/cdi/IGlobalSystemSetupListener
at java.lang.ClassLoader.defineClass1(Native Method)
at java.lang.ClassLoader.defineClass(Unknown Source)
at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.defineClass(DefaultClassLoader.java:160)
at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.defineClass(ClasspathManager.java:498)
at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findClassImpl(ClasspathManager.java:468)
at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLocalClassImpl(ClasspathManager.java:427)
at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLocalClass(ClasspathManager.java:410)
at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.findLocalClass(DefaultClassLoader.java:188)
at org.eclipse.osgi.framework.internal.core.BundleLoader.findLocalClass(BundleLoader.java:339)
at org.eclipse.osgi.framework.internal.core.BundleLoader.findClass(BundleLoader.java:391)
at org.eclipse.osgi.framework.internal.core.BundleLoader.findClass(BundleLoader.java:352)
at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loadClass(DefaultClassLoader.java:83)
at java.lang.ClassLoader.loadClass(Unknown Source)
at org.eclipse.osgi.framework.internal.core.BundleLoader.loadClass(BundleLoader.java:276)
at org.eclipse.osgi.framework.internal.core.BundleHost.loadClass(BundleHost.java:227)
at org.eclipse.osgi.framework.internal.core.AbstractBundle.loadClass(AbstractBundle.java:1245)
at org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI.createExecutableExtension(RegistryStrategyOSGI.java:147)
at org.eclipse.core.internal.registry.ExtensionRegistry.createExecutableExtension(ExtensionRegistry.java:759)
at org.eclipse.core.internal.registry.ConfigurationElement.createExecutableExtension(ConfigurationElement.java:243)
at org.eclipse.core.internal.registry.ConfigurationElementHandle.createExecutableExtension(ConfigurationElementHandle.java:51)
at com.ti.common.ui.decorations.DecorationManager$PartListener.partOpened(DecorationManager.java:132)
at com.ti.common.ui.decorations.DecorationManager$PartListener.<init>(DecorationManager.java:86)
at com.ti.common.ui.decorations.DecorationManager$WindowListener.windowOpened(DecorationManager.java:63)
at com.ti.common.ui.decorations.DecorationManager$WindowListener.<init>(DecorationManager.java:54)
at com.ti.common.ui.decorations.DecorationManager$1.run(DecorationManager.java:209)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:35)
at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchronizer.java:123)
at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.java:3325)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:2971)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.java:1914)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1878)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:419)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:149)
at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplication.java:97)
at org.eclipse.core.internal.runtime.PlatformActivator$1.run(PlatformActivator.java:78)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:92)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:68)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:400)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:177)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
at java.lang.reflect.Method.invoke(Unknown Source)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:336)
at org.eclipse.core.launcher.Main.basicRun(Main.java:280)
at org.eclipse.core.launcher.Main.run(Main.java:996)
at org.eclipse.core.launcher.Main.main(Main.java:971)
at org.eclipse.core.launcher.Main.main(Main.java:950)
at com.ti.ccstudio.scripting.CCSSession$CCSLauncher.run(CCSSession.java:36)
at java.lang.Thread.run(Unknown Source)
Caused by: java.lang.ClassNotFoundException: com.ti.ccstudio.debug.core.cdi.IGlobalSystemSetupListener
at org.eclipse.osgi.framework.internal.core.BundleLoader.findClass(BundleLoader.java:407)
at java.lang.ClassLoader.loadClassInternal(Unknown Source)
... 54 more
!ENTRY org.eclipse.ui 4 4 2010-12-16 15:27:42.714
!MESSAGE Unhandled event loop exception
!ENTRY org.eclipse.ui 4 0 2010-12-16 15:27:42.714
!MESSAGE Failed to execute runnable (java.lang.NullPointerException)
!STACK 0
org.eclipse.swt.SWTException: Failed to execute runnable (java.lang.NullPointerException)
at org.eclipse.swt.SWT.error(SWT.java:3374)
at org.eclipse.swt.SWT.error(SWT.java:3297)
at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchronizer.java:126)
Caused by: java.lang.NullPointerException
at com.ti.common.ui.decorations.DecorationManager$PartListener.partOpened(DecorationManager.java:146)
... 27 more
!ENTRY org.eclipse.osgi 4 0 2010-12-16 15:27:42.793
!MESSAGE An error occurred while automatically activating bundle com.ti.dvt.ideadapterplugin (135).
!STACK 0
org.osgi.framework.BundleException: Exception in com.ti.dvt.ideadapter.IDEAdapterPlugin.start() of bundle com.ti.dvt.ideadapterplugin.
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.startActivator(BundleContextImpl.java:1014)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.start(BundleContextImpl.java:970)
at org.eclipse.osgi.framework.internal.core.BundleHost.startWorker(BundleHost.java:317)
at org.eclipse.osgi.framework.internal.core.AbstractBundle.start(AbstractBundle.java:256)
at org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter.preFindLocalClass(EclipseLazyStarter.java:86)
at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLocalClass(ClasspathManager.java:409)
at org.eclipse.ui.internal.WorkbenchPlugin$1.run(WorkbenchPlugin.java:242)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator.java:49)
at org.eclipse.ui.internal.WorkbenchPlugin.createExtension(WorkbenchPlugin.java:238)
at org.eclipse.ui.internal.EarlyStartupRunnable.getExecutableExtension(EarlyStartupRunnable.java:117)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:58)
Caused by: java.lang.NoClassDefFoundError: com/ti/debug/engine/framework/IDisposable
at java.lang.Class.getDeclaredConstructors0(Native Method)
at java.lang.Class.privateGetDeclaredConstructors(Unknown Source)
at java.lang.Class.getConstructor0(Unknown Source)
at java.lang.Class.newInstance0(Unknown Source)
at java.lang.Class.newInstance(Unknown Source)
at org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI.createExecutableExtension(RegistryStrategyOSGI.java:157)
at com.ti.dvt.ideadapter.IDEAdapterPlugin.getIDEAdapterList(IDEAdapterPlugin.java:63)
at com.ti.dvt.ideadapter.IDEAdapterManager.getIDEAdapterList(IDEAdapterManager.java:154)
at com.ti.dvt.ideadapter.IDEAdapterManager.getIDEList(IDEAdapterManager.java:170)
at com.ti.dvt.ideadapter.IDEAdapterManager.setIDEAdapterManagerList(IDEAdapterManager.java:65)
at com.ti.dvt.ideadapter.IDEAdapterPlugin.start(IDEAdapterPlugin.java:120)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl$2.run(BundleContextImpl.java:995)
at java.security.AccessController.doPrivileged(Native Method)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.startActivator(BundleContextImpl.java:989)
... 26 more
Caused by: java.lang.ClassNotFoundException: com.ti.debug.engine.framework.IDisposable
... 43 more
Root exception:
... 43 more
!ENTRY org.eclipse.ui.workbench 4 2 2010-12-16 15:27:42.794
!MESSAGE Problems occurred when invoking code from plug-in: "org.eclipse.ui.workbench".
!STACK 1
org.eclipse.core.runtime.CoreException: Plug-in com.ti.dvt.ideadapterplugin was unable to load class com.ti.dvt.ideadapter.IDEAdapterStartup.
at org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI.throwException(RegistryStrategyOSGI.java:165)
at org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI.createExecutableExtension(RegistryStrategyOSGI.java:149)
org.eclipse.core.runtime.CoreException[1]: java.lang.ClassNotFoundException: com.ti.dvt.ideadapter.IDEAdapterStartup
!SUBENTRY 1 org.eclipse.equinox.registry 4 1 2010-12-16 15:27:42.794
!MESSAGE Plug-in com.ti.dvt.ideadapterplugin was unable to load class com.ti.dvt.ideadapter.IDEAdapterStartup.
!STACK 0
!STACK 0
!ENTRY org.eclipse.ui 4 4 2010-12-16 15:27:42.795
!MESSAGE Unhandled Exception
!ENTRY com.ti.dvt.ideadapterplugin 4 0 2010-12-16 15:27:42.796
!MESSAGE Unable to execute early startup code for an extension
!STACK 1
!SUBENTRY 1 org.eclipse.equinox.registry 4 1 2010-12-16 15:27:42.796
!STACK 0
!ENTRY org.eclipse.osgi 4 0 2010-12-16 15:27:42.809
!MESSAGE An error occurred while automatically activating bundle com.ti.dvt.trace (155).
!STACK 0
org.osgi.framework.BundleException: Exception in com.ti.dvt.trace.TracePlugin.start() of bundle com.ti.dvt.trace.
Caused by: java.lang.NoClassDefFoundError: com/ti/dvt/ideadapter/IDEAdapterPlugin
at com.ti.dvt.trace.TracePlugin.start(TracePlugin.java:141)
... 26 more
Root exception:
!ENTRY org.eclipse.ui.workbench 4 2 2010-12-16 15:27:42.810
!STACK 1
org.eclipse.core.runtime.CoreException: Plug-in com.ti.dvt.trace was unable to load class com.ti.dvt.trace.TraceStartup.
org.eclipse.core.runtime.CoreException[1]: java.lang.ClassNotFoundException: com.ti.dvt.trace.TraceStartup
!SUBENTRY 1 org.eclipse.equinox.registry 4 1 2010-12-16 15:27:42.811
!MESSAGE Plug-in com.ti.dvt.trace was unable to load class com.ti.dvt.trace.TraceStartup.
!STACK 0
!STACK 0
!ENTRY org.eclipse.ui 4 4 2010-12-16 15:27:42.811
!ENTRY com.ti.dvt.trace 4 0 2010-12-16 15:27:42.812
!STACK 1
!SUBENTRY 1 org.eclipse.equinox.registry 4 1 2010-12-16 15:27:42.812
!STACK 0
Caused by: java.lang.ClassNotFoundException: com.ti.debug.engine.cce.IDebugEngine$IFactory
... 8 more
starting addListenerThread
The attached file is the error log exported from the CCS IDE
