I have a build using a C2000 compiler that outputs my assembly output from the assembly of my C files and using CCS 5.5 I can open the assembly files and with the CCS editor i have syntax highlighting setup to easily find the assmbly commands.
My main question, does TI provide a tool that can strip all the TI assembly attributes out and leave just the assembly commands and demangle the function names (I have C++ also)? I would like to have setup where i can have the C file and a corresponding assembly open and after compiling gives me the pure assembly to compare side by side with the original code.
Thank you
Edit: I am aware of the dem2000 tool for demangling the assembly files.
