While doing some tests our customer found a (seemingly) strange behavior, when placing members of an unpacked struct into memory.
Here is some code and according ouputs.
In both cases (UnpaddedStruct and PaddedStruct) the offset for the struct being placed into memory is memory+7 each.
In the latter case (PaddedStruct) the effective offset is memory+4. How comes? Sure, it has something to do with 32bit alignment...
Is there a compiler option we missed to change the behavior here? (pragma, etc...)
#pragma pack(push,1)
typedef struct {
int32_t i1;
uint8_t c1;
int32_t i2;
} UnpaddedStruct;
#pragma pack(pop)
typedef struct {
int32_t i1;
uint8_t c1;
int32_t i2;
} PaddedStruct;
unsigned char memory[32];
void test3()
memset(memory, 0xFF, sizeof(memory));
UnpaddedStruct *unpadded = (UnpaddedStruct*)(memory + 7);
unpadded->i1 = 0xaaaaaaaa;
unpadded->c1 = 0xcc;
unpadded->i2 = 0xbbbbbbbb;
xprint("\nmemory", memory, sizeof(memory));
PaddedStruct *padded = (PaddedStruct*)(memory + 7);
padded->c1 = 0xcc;
memory:
0 ffffffff ffffffaa aaaaaacc bbbbbbbb | |
10 ffffffff ffffffff ffffffff ffffffff | |
memory:
0 ffffffff aaaaaaaa ffffffcc bbbbbbbb | |
