Where can I find an IBIS model for the TLE2142MD? I need it to run simulations in Hyperlynx on my PCB I am having layed out.
Your help is appreciated
Richard,
I understand your desire to bring all the appropriate models into your siumation environment as you are working to refine your layout, however, the TLE2142 is an anlog amplifier. It has not digital input or output pins. The intentions of an IBIS model is to evaluate your board in terms of signal integrity in the digital domain.
If you are curious about layout guidelines fo rth eTLE2142, please refer to analog layout rules and guidelines.
The appropirate simualtion model for the TLE2142 would be a TINA or SPICE model. These models will help you determine if electircally the circuit will orperate correctly.
