Hi all,
I am designing an Power ORing with 2 TPS22953 devices
The TINA model of TPS22953 shows a wrong behaviour
Normally when the SNS pin goes from high to low, the Switch output is disabled for Trestart (datasheet page 24)
When I test it in TINA, the macromodel does not disable the output but simply switch the PG output
Can you confirm my observation ?
Thank you
David
