Hi to all, I would like design a PSU using Webench:
I set input power supply values (x example, from 11.0 to 21.0 Volts), but working voltage should be 12 Volts.
In Efficiency chart I can find efficiency for 11.0 Volts, for 21.0 Volts and for 16.0 Volts (I suppose 16 is the average value between 11 and 21 Volts).
I need to know efficiency values for 12.0 Volts (nominal working voltage) to select among several devices and get most efficient one.
Is there a way to do this?
Thanks.
