Can someone fix the Voltage input Range of the TPS51216. Right now it only accepts 8 - 28V. The actual input Range is 3 - 28V and I would like to run a simulation on this part.
Thank you,
Thank you,
Hi Brian,
Due to modeling constraints, there was a decision to fix the input range to 8 - 28V for the model to be on the conservative side of duty cycles. I'll delve into this a bit deeper and get back to you soon.
