In this design, which Web Bench Created, It uses an LM5036, but that part does'tn exisit.. What part coudl this be. Here is the link to the design..
webench.ti.com/.../webench5.cgi
Hi Andrew,
I do not see an active product page for LM5036. When I open your link, it opens a different part number (TPS54062) design for me. Would it be possible for you to look at sharing the design using the "Share Design" -> "Share with Public" URL? I am sharing an example snapshot below for this.
I can also ask someone from the team to look at LM5036 availability in the tool and on ti.com page.
Amod
Attached is a pdf of the design. I'm not sure why the link doe'snt work, becuase I did exactly what you suggested. When i click on the link it takes me to the correct design. Your not the only one that has mentioned this problem though.
Hopefully you'll be able to see from teh PDF anyway.. I did create the link from the Share public design
webench.ti.com/.../SDP.cgi
