Other Parts Discussed in Thread: SN74LV4T125
Hello, I was trying to trigger my camera using DLP3010EVM trigger output. I used J4 pin (4th pin) and ground for trigger output. However, the output voltage is on 3.26V and my camera require 3.3V. So it does not work. I tested my camera using a higher voltage source, and it worked. That means my camera is fine. It is just the output voltage is not enough. Any suggestions? Thank you guys!
