Other Parts Discussed in Thread: DLPC900, DLPC350
As explain in an other that I asked in this forum, I am currently trying to upload an image on my DMD from matlab using the Programer's Guide.
To do so, it is necessary to use a flash adress, and the Guide told us to be carefull because the firsts kB of data are used to store some valuable information pour the chip.
Is there a way to access which adress is safe, and what flash image number it will refer to ?
Also, according to the Programer's Guide of the DLPC900, the data send should be compressed using Run-Length Encoding, but the DLPC350 Guide do not mention anything about the possible encoding that is necessary on this device. Are we supposed to send data compressed by RLE ? By an other method ? Or juste 1Bytes per pixel ?
Thank you very much,
Thomas
