Dear All,
I would like to specify always DMD ON state in order to measure output LED illumination power.
Is DMD always ON state when test pattern of solid field specified regardless of the colors we specify?
Rossinag
Dear All,
Rossinag
Hello Philippe,
Thank you for your response. I understood.
For my understanding please let me ask you about the solid white field test pattern.
In that case which image source is used? RGB24bit picture(means 24 bit planes) or a 1bit binary bit plane?
Rossinag
Hello Philippe,
Thank you for your comment.
OK, we will use the solid white internal test pattern for our testing. Is this a RGB 24bit(all on) picture?
In further my investigation, it looks that DLPC3435 cannot display 1bit binary pattern. In other words splash must be a RGB picture and cannnot specify 1 bit binary picture (it like ALC DMD controller). Is this correct understanding?
Rossinag
Rossinag,
This EVM does not display 1-bit binary patterns, you are correct.
Let me know if you need further assistance.
Philippe Dollo
