Flash Tool Support for Windows 7
Dear Team,
    We have a customer, who is trying to install Flash tool (http://processors.wiki.ti.com/index.php/Flash_v1.6_User_Guide) on a Windows 7 machine but are facing issues. As per the documentation, there is no mention of Windows 7 support, so just wanted to check if its available.
Thanks & Regards,
Amit
  • I was able to successfully install the program on Win7 x64 by using the Windows Compatibility Tool.
    • Right-click the installer
    • Select "Troubleshoot Compatibility"
    • Select "Try Recommended Settings"
    • Select "Save these settings for this program".
    Win7 will now provide a WinXP SP2 environment for the program whenever it is run.
    -DK
  • Hi
    I was able to install Flash tool on Win7 but failed installing drivers. After installing the Flash tool. I tried erasing the nand flash but when you reset the board it will search for the OMAP Drivers. Flash tool has got drivers, that i have used with win xp. But when i point same drivers in case of windows 7 it is not accepting those drivers. It seems there is a problem in driver compatibility... Please help here.
    regards
    Sobin Thomas
