Hi Colleagues,
Do we have any product or app note on how to galvanically isolate HDMI/DVI signals?
Hi Colleagues,
Thank you Clemens.
This is a standard 1080p 60Hz Full HD stream, to clarify.
Would you be able to elaborate some more on a possible solution and part number?
Hi Clemens,
Thank you for your input on this matter.
I'm not really educated on this subject, so my understanding from the above is that HDMI uses TDMS, therefore a type of CML, which can then be converted to LVDS. Is my assumption correct?
Also, can you describe how to calculate the required bandwidth for an HDMI/DVI signal? I would assume this would only depend on the refresh rate and resolution, but perhaps I'm being overly simplistic.
