• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Low Power RF & Wireless Connectivity » Low Power RF Bluetooth® Low Energy & ANT Forum » Texas Instruments BLE Stack 1.3 Released
Share
  • Forums
  • Announcements
  • Files
  • E2E Wiki
Options
  • Subscribe via RSS
  • Joakim Lindh
    Posted by Joakim Lindh
    on Jan 04 2013 04:35 AM
    Genius13370 points
    The Texas Instruments Bluetooth® low energy (BLE) software development kit includes all necessary software to get started on the development of single-mode BLE applications using the CC2540/41 system-on-chip. It includes object code with the latest BLE protocol stack supporting multiple connections, sample projects and applications covering an extensive set of profiles with source code, and BTool, a Windows PC application for testing BLE applications. In addition to the software, the kit contains documentation, including a developer’s guide, sample applications guide, and BLE API guide.
    Download SW at ti.com/ble-stack
    CC2540/41 Bluetooth Low Energy Software Development Kit
    Release Notes
    Version 1.3
    Dec 12, 2012
    Notices:
    - This version of the Texas Instruments BLE stack and software features several
    changes, enhancements, and bug fixes from v1.2.1. Details of these can be found
    below.
    Changes and Enhancements:
    - A new sample project, SensorTag, has been added. This application runs on the
    CC2541 Sensor Tag board, which is included as part of the CC2541DK-SENSOR
    development kit. The application includes custom services for an accelerometer,
    barometer, gyro, humidity sensor, IR temperature sensor, and magnetometer.
    - A new Boot Image Manager (BIM) is included. This allows one CC2540 or CC2541
    device to contain two separate software images (an "A" image and a "B" image)
    stored in flash. Upon power-up, the BIM selects which image to boot into. This
    can be based on criteria such as the state of a GPIO pin, or based on a
    selection from the previously running application upon reset.
    - A new Over-the-air firmware download (OAD) feature is included. The feature
    allows a peer device (which could be a central BT Smart device such as a
    smartphone) to push a new firmware image onto a peripheral device and update
    the firmware. This feature uses the BIM, in which case the downloaded image
    gets stored in the opposite flash location as the currently running image.
    For example, if the "A" image is the current image and is used to perform the
    download, then the downloaded image becomes the "B" image. Upon reset, the "B"
    image with the updated firmware would be loaded. The OAD feature optionally
    allows for the firmware image to be signed (using AES). Both the SensorTag and
    SimpleBLEPeripheral projects include configurations for using the OAD feature.
    A central "OADManager" application is also included, demonstrating a central
    implementation for sending a new firmware image to an OAD target device.
    - The physical HCI interface used by the network processor (HostTestRelease) has
    been enhanced to work while power management is enabled on the CC254x device.
    The UART interface, when using RTS and CTS lines, can be used by an
    external application processor to wake-up the CC254x network processor. When
    the network processor has completed all processing, it will go into deep
    sleep. In addition to UART, an SPI interface has been added as an option for
    the physical HCI interface. It also supports power management by means of
    the MRDY and SRDY lines.
    - The CC2541 configuration of the KeyFobDemo project has been modified to
    support the new CC2541 keyfob hardware, contained in the CC2541DK-MINI kit.
    The accelerometer has been changed, and a TPS62730 DC/DC converter has been
    added.
    - The structure of all projects have been changed to include a Transport Layer
    ("TL") library and network processor interface "NPI" source code. This new
    architecture allows for non-network processor applications to have slightly
    reduced code size by removing unnecessary stack components.
    - An API has been provided allowing the device name and appearance
    characteristics in the GAP service to be modified by the application layer.
    - KeyFobDemo project now includes visual feedback from LED to indicate when
    device has powered up and when device is advertising.
    - The HID-over-GATT Pofile (HOGP) implementation has been updated to now
    queue up HID report and send notifications upon reconnection to a HID host.
    - A new implementation of the HID service has been included, which supports
    a combined keyboard, mouse, and consumer class device in its HID report
    descriptor.
    - The API for sending L2CAP Connection Parameter Update Requests from the GAP
    Peripheral Role Profile has been updated to take both the requested minimum
    and maximum connection intervals as parameters.
    - BTool has been enhanced with a new GATT explorer table, displaying discovered
    attributes, handles, and values. An XML file is included which allows the
    user to define descriptions of characteristics based on their UUIDs.
    - HCI UART interface baud rate has been changed from 57600 to 115200.
    Bug Fixes:
    - When power management is used with long connection intervals (>2s), the
    CC254x remains sleeping properly without unnecessary wake-ups.
    - When slave latency is used, peripheral devices now properly wake-up before
    the next connection event when a data packet is queued
    - Various bug fixes on the GlucoseSensor and GlucoseCollector projects to
    improve compliance with profile and service specifications.
    - HID-over-GATT Pofile (HOGP) implementation has been updated to provide
    better interoperability with HID hosts.
    Known Issues:
    - Use of the NV memory (to save application data or BLE Host bonding
    information) during a BLE connection may cause an unexpected disconnect.
    The likelihood of this happening increases with frequent usage, especially
    when using short connection intervals. The cause is related to the NV wear
    algorithm which at some point may cause an NV page erase which can disrupt
    system real-time processing. It is therefore recommended that the NV memory
    be used sparingly, or only when a connection is not active.
    - HCI packet size of 128 bytes or more will be disregarded by the stack, and as such,
    no HCI event will be returned.
    Report Abuse
    • Reply
    You have posted to a forum that requires a moderator to approve posts before they are publicly available.
  • Jonathan Cohn
    Posted by Jonathan Cohn
    on Dec 20 2012 08:21 AM
    Expert1665 points
    Nick, this is exciting stuff. I was getting antsy waiting for this news.
    Can you tell me about what was addressed in 1.3 regarding this bug: http://e2e.ti.com/support/low_power_rf/f/538/t/227515.aspx
    My device relies heavily on UART communication while broadcasting characteristic data, so I'd like to keep the processor on all the time (as battery life is not a worry for me)
    Report Abuse
    • Reply
  • Stan 59800
    Posted by Stan 59800
    on Dec 22 2012 22:29 PM
    Intellectual380 points
    Which IAR version(s) will work with the new stack and examples?
    Report Abuse
    • Reply
  • Simon Chambers
    Posted by Simon Chambers
    on Jan 02 2013 10:28 AM
    Prodigy130 points
    It works fine on version 8.11 for me. As BLE Stack version 1.21 required 8.11, I would imagine that BLE Stack version 1.3 requires this too.
    No idea if it works on version 8.20.
    Si.
    Report Abuse
    • Reply
  • kesly
    Posted by kesly
    Prodigy50 points
    Good News !
    Group Not Found.....The requested Group cannot be found.
    How can i get it? I have submitted some information on the website
    Report Abuse
    • Reply
  • Aslak N.
    Posted by Aslak N.
    on Jan 04 2013 04:40 AM
    Expert5440 points
    Hi Kesly,
    There was a problem with the link - it lacked http://. Try again after a refresh, or type the address ti.com/ble-stack directly into your web-browser.
    Aslak
    Report Abuse
    • Reply
  • Andre S
    Posted by Andre S
    on Jan 07 2013 06:23 AM
    Intellectual820 points
    did you omit the fix ( http://e2e.ti.com/support/low_power_rf/f/538/t/72681.aspx ) for the dynamic update of advertisement data on purpose?
    Report Abuse
    • Reply
  • Aslak N.
    Posted by Aslak N.
    on Jan 07 2013 06:49 AM
    Expert5440 points
    Hi Andre,
    No. It must have slipped through the cracks. However, you can call GAP_UpdateAdvertisingData( <your task id>, TRUE, <len>, <array with advdata> ); from the application at any time to update the advertisement data. FALSE if ScanRsp.
    Aslak
    Report Abuse
    • Reply
  • Andre S
    Posted by Andre S
    on Jan 08 2013 04:44 AM
    just to be sure:
    is there a bugtracking system where we (the forum users) are able to submit these issues and where we are able to keep track of fixes, etc in the different releases?
    if not: why?
    Report Abuse
    • Reply
  • Aslak N.
    Posted by Aslak N.
    on Jan 08 2013 04:53 AM
    Expert5440 points
    There isn't. It's because there are many details in the bug tracking that can not be made public, and the system we use doesn't allow differentiating between internal and external viewers. Thanks for pointing out bugs on e2e, and feel free to continue doing so :)
    - Aslak
    Report Abuse
    • Reply
  • Joakim Lindh
    on Jan 10 2013 06:12 AM
    Genius13370 points
    A guide to port BLEv1.2 projects to the BLEv1.3 stack is available at the BLE wiki (www.ti.com/ble-wiki). Fast link to it: http://processors.wiki.ti.com/index.php/LPRF_BLE_Porting_Projects.
    Let us know if something is unclear.
    Best Regards
    Report Abuse
    • Reply
  • Vladim-ir
    Posted by Vladim-ir
    on Jan 11 2013 00:28 AM
    Prodigy190 points
    Hello, everyone!
    I try to download new BLE-STACK 1.3, but downloaded file is wrong. It only has 9kB size and of course error occures while openning the file. Is it possible to fix the link?
    Report Abuse
    • Reply
  • Jerome Baron
    Posted by Jerome Baron
    on Jan 11 2013 08:21 AM
    Intellectual560 points
    Same here! Download is only 9kB...
    Please fix the link
    Report Abuse
    • Reply
  • Aslak N.
    Posted by Aslak N.
    on Jan 11 2013 08:34 AM
    Expert5440 points
    Something is apparently wrong. The responsible division has been notified. In the meantime, try renaming the downloaded .zip file to .htm and open it. This should start the real download process.
    Aslak
    Report Abuse
    • Reply
  • Jerome Baron
    on Jan 11 2013 08:40 AM
    lol, nice hack. It works!
    Report Abuse
    • Reply
12
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
