• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Microcontrollers » C2000™ Microcontrollers » C2000 32-bit Microcontrollers Forum » About the Solar Liberary Function of C2000™ Solar Inverter Development Kits
Share
  • Forums
  • Announcements
  • E2E Wiki
Options
  • Subscribe via RSS
C2000 Resources
  • Product Folder
  • C2000 Training Portal
  • C2000 Technical Training Catalog
  • C2000 Datasheets, App Notes, User Guides
  • C2000 Hardware Design Kits
  • controlSUITE for C2000 Software Library
  • InstaSPIN Resources
  • What is InstaSPIN?
  • Videos and Support
  • InstaSPIN-FOC and InstaSPIN-MOTION Resources
  • What is InstaSPIN-FOC?
  • What is InstaSPIN-MOTION?
  • Product Folder: F28069F, F28068F, F28062F, F28068M, F28069M
  • User’s Guide
  • Technical User’s Manual
  • Tools
  • About the Solar Liberary Function of C2000™ Solar Inverter Development Kits
    This question is not answered
    jim kuo
    Posted by jim kuo
    on Feb 09 2012 23:50 PM
    Prodigy30 points
    I'm interesting in Solar Inverter Development Kits
    If i want to know more about  the Solar Liberary Function of C2000™ Solar Inverter Development Kits
    where can find more about  Solar Liberary Function's information ?
    Report Abuse
    • Reply
    You have posted to a forum that requires a moderator to approve posts before they are publicly available.
    All Replies
    • Manish Bhardwaj
      Posted by Manish Bhardwaj
      on Feb 10 2012 10:20 AM
      Expert7390 points
      Jim,
      All the information is in controlSUITE v2.8.0,
      Please update and you will find it under,
      controlSUITE\libs\app_libs\solar
      regards
      Manish Bhardwaj
      Report Abuse
      • Reply
    • jim kuo
      Posted by jim kuo
      on Feb 13 2012 04:53 AM
      Prodigy30 points
      Hi Manish,
      I have some problem want to ask .
      I find those data in controlSUITE, but when I want to open the project
      It shows this error
      what should I do
      Report Abuse
      • Reply
    • Manish Bhardwaj
      on Feb 13 2012 09:37 AM
      Expert7390 points
      jHi,
      There is an error in the Controlsuite Desktop,we do not have any template projects for the solar library, it's being used only by the development kits.
      Please try to open it from the Kits-> Solar Explorer -> PV Inverter F2803x project, (currently the description reads PV emulator, This should read PV inverter, we will fix this in the next update)
      Or alternatively you can follow the user guide that describes how to open the projects,
      ,controlSUITE\development_kits\SolarExplorer_v1.0\SolarExplorer_PVInverter_F2803x\~Docs
      Manish Bhardwaj
      Report Abuse
      • Reply
    • jim kuo
      Posted by jim kuo
      on Feb 19 2012 20:29 PM
      Prodigy30 points
      HI
      I saw the SolarLib_float.pdf,
      but I  have some question about the content
      first, i couldn't understand the section explains how to use this module
      it's means I need to ceate a new project then add the new "Main.c" file??
      Report Abuse
      • Reply
    • Manish Bhardwaj
      on Feb 20 2012 09:28 AM
      Expert7390 points
      Jim,
      The solar library documentation is to be used in conjunction with the sample project in this case the sample projects are  found here,
      Adequate documentation is provided in the library document to explain the module algorithm and software interface,
      the library documentation does not include steps on starting a new project, that is not the objective of the document.
      Manish Bhardwaj
      Report Abuse
      • Reply
    • qiu wei
      Posted by qiu wei
      on Mar 12 2012 22:21 PM
      Prodigy75 points
      HI, Manish:
      About the spll provided by TI , I have ported the algorithm  to my pv inverter project, and it works well.
      But I want to know if the calculation of  theta[0] in the algorithm is OK? is the range of theta[0] between 0 to 2PI?
      TKS!
      Report Abuse
      • Reply
    • qiu wei
      Posted by qiu wei
      on Mar 14 2012 00:31 AM
      Prodigy75 points
      HI, Manish:
      Are you online? I need your help.
      Report Abuse
      • Reply
    • qiu wei
      Posted by qiu wei
      on Mar 14 2012 11:07 AM
      Prodigy75 points
      Any body can help me ?
      Report Abuse
      • Reply
    • Manish Bhardwaj
      on Apr 09 2012 08:18 AM
      Expert7390 points
      Wei,
      The PLL code does not directly use the theta value as it uses DCO for the sine and the cos values,
      The PLL code has the following snippet:
      if(spll_obj->sin[0]>(0.0) && spll_obj->sin[1]<=(0.0))
              spll_obj->theta[0]=(0.0);
      As the condition is applied to sin value going from negative to positive, the theta range is from zero to 2*pi,
      Manish Bhardwaj
      Report Abuse
      • Reply
    • qiu wei
      Posted by qiu wei
      on Apr 24 2012 11:28 AM
      Prodigy75 points
      dear Manish Bhardwaj,
      (1) in the pll code has the following snippet:
      v.theta[0]=v.theta[1]+SPLL_Qmpy(v.wn,SPLL_Q(0.00001591549));
      so, the range of theta[0] is from 0 to 2,  not 2*pi, right ?
      (2) for above code, why not v.theta[0]=v.theta[1]+SPLL_Qmpy(v.wo,SPLL_Q(0.00005));
      if write like this, i think that is the real time angle of grid voltage, and the range is from  zero to 2*pi, right?
      Report Abuse
      • Reply
    • Manish Bhardwaj
      on Apr 25 2012 09:24 AM
      Expert7390 points
      Ok,
      Well i had modelled the PLL in matlab first so in that the range was kept from o to 2 * pi,
      when using fixed point maths it's better to scale everything from 0 -> 1 , so to keep this you multiply the delta theta by 1/2*pi,
      Now initially the PLL calling frequency was 10Khz and hence the 0.0000159, this should be replaced with delta_T/(2*pi) or something,
      Sorry for the confusion, it will be corrected in the next release of the software,
      Manish Bhardwaj
      Report Abuse
      • Reply
    • qiu wei
      Posted by qiu wei
      on Apr 26 2012 20:28 PM
      Prodigy75 points
      Dear Manish Bhardwaj:
      I really understand you.
      so, do you think my code "v.theta[0]=v.theta[1]+SPLL_Qmpy(v.wo,SPLL_Q(0.00005));" right or not ?
      in my practical test, v.theta[0] is not the real time grid voltage angle if computing based on the above equation.
      I suspect that in your spll algorithm, we can get sin[0] and cos[0], but we can not get theta[0], maybe this is
      relevant to the algorithm.
      I look forward to your reply and new software release.
      Report Abuse
      • Reply
    • Manish Bhardwaj
      on Apr 27 2012 14:07 PM
      Expert7390 points
      Wei the correct one is
      spll_obj->theta[0]=spll_obj->theta[1]+(spll_obj->wn*(0.00000795));
      or you can do
      spll_obj->theta[0]=spll_obj->theta[1]+(50*(0.00005));
      i will recommend the latter,
      Note as wo is 2*pi*f the delta in the first equation is 0.00005/(2*pi)
      Report Abuse
      • Reply
    • qiu wei
      Posted by qiu wei
      on Apr 27 2012 19:59 PM
      Prodigy75 points
      OK, you recommend the equation :
      for the frequency equals to 50Hz, it is maybe OK,
      but if grid frequency changes to 48Hz, 49Hz,51Hz, 52Hz,
      the theta[0] does not equal to the angle of grid.
      Report Abuse
      • Reply
    • Manish Bhardwaj
      on Apr 30 2012 14:34 PM
      Expert7390 points
      You are right,
      Use this then, wo is the frequency feeding the VCO and shall adapt to the grid conditions,
      spll_obj->theta[0]=spll_obj->theta[1]+(spll_obj->wo*(0.00000795));
      regards
      Report Abuse
      • Reply
    12
    TI E2E™ Community
    • Support Forums
    • Blogs
    • Videos
    • Groups
    • Site Support & Feedback
    • Settings
    TI E2E™ Community Groups
    • TI University Program
    • Make the Switch
    • Microcontroller Projects
    • Motor Drive & Control
    Other Communities
    • Deyisupport
    • Designsomething.org
    • beagleboard.org
    • TI on Element 14
    • TI on TechXchangeSM
    Other Technical & Support Resources
    • WEBENCH® Design Center
    • Product Information Centers
    • Technical Documents
    • TI Design Network
    • TI Technical Articles
    • TI Training
    All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
    Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
    Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
    TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
    TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
    embedded processors, along with software, tools and the industry’s largest sales/support staff.
    © Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
    Trademarks | Privacy Policy | Terms of Use
