I'm working on an old design that uses an F2812. The code uses several FIR filters that have 256 coefficients. I need to reduce the CPU load and thought I'd try using IIR filters instead. I've come across sprc082 http://focus.ti.com/docs/toolsw/folders/print/sprc082.html and found there's a Matlab file called eziir32.m for designing an IIR filter for use with the TI library.
Does anyone know if the file iir32.asm will work with the F2812?
Should I be looking elsewhere?
I'd really like 145dB of attenuation, but the script crashes at 145dB attenuation. It might be an octave bug, and not the case under Matlab.
Any thoughts?
James.
