HI all,
I am working on DAC interfacing with EzDSP-F28335 Evaluation board.
For 4-channel DAC configuration, I need to toggle the GPIO port pins accordingly to provide address of channel for
writing data to a particular channel. For selecting the channel I have implemented 'Switch:Case'.(attached)
According to data sheet DAC write should complete with in 100nsec but it takes 1usec.(measured on oscilloscope by toggling a GPIO before and after the DAC function call)
When we start analysis then we found that GPIO is taking more time(approx 2-3 cycles: measured with CCSv4 clock cycles) for set or clear instruction.
Example: GpioDataRegs.GPASET.bit.GPIO1 = 1;
I have referred this link and changed the GPIO set and clear instructions in assembly(attached)
http://e2e.ti.com/support/microcontrollers/c2000/f/171/t/58087.aspx
But in both cases the time it is taking to complete the DAC writing is same i.e., 1us (measured on oscilloscope by toggling a GPIO before and after the DAC function call).
Please help me to reduce the timings.
Thankyou,
Lakshmi.
