The problem is that your memory usage has grown too large to fit into the flash sector A alone.
The OR'ing you perform, .econst : > FLASHA | FLASH D tells the linker to allocate the econst section as a whole into the first memory range in which it fits completely A or D
you can alternatively change that line to: .econst : >> FLASHA | FLASH D (note the extra right angled bracket) which will "split" the .text section across multiple memory regions A and D
See: processors.wiki.ti.com/.../C28x_Compiler_-_Understanding_Linking
