Has anyone out there loaded Blinky (or something similar / simple) into flash using the SCI bootstrap mechanism and a suitable flash kernel and run it successfully, just to test the process and better understand the documentation? If so, can you please show me how to do it? And if you can, also describe how you got the flash kernel to compile using CCS and link in the first place? I am using ControlSuite 3.4 (V200 files) and CCSV6.
I have reached the bottom of a pit of despair over what should be the easiest of tasks, and am dying under the weight of complex documentation and lack of success in compiling the kernel, and to make things worse, the Serial_Flash_programmer utility won't even compile on Visual Studio v10 - lots of missing references and files.
Many thanks in anticipation!
Chris
