TMS320F28379D: T-Format Library functions CPU cycles
Part Number: TMS320F28379D
Hi Champion
My customer evaluated T-format, and have a question as below:
The User Guide said PM_fformat_receiveData need 500 CPU cycles, but when we debug in the CCS, it will take 2000+ CPU cycles. We also use oscilloscope to measure the execution time, it's about 11us (CPU @ 200Mhz Freq).
Other functions all looks good except PM_fformat_receiveData, is there anything wrong?
Thanks a lot.
BR,
Sam
  • Hello Samsai,
    Cycles taken by PM_fformat_receiveData function depends on the command being used, type of the encoder, data width, CRC polynomial/check etc.
    As noted in the document -
    "CPU cycle data depends on Encoder under test, and the commands/data being used along with certain function. These numbers could vary significantly depending on the command and corresponding data, and so forth."
    So, to answer your question - "Other functions all looks good except PM_fformat_receiveData, is there anything wrong?"
    I don't think there is anything wrong so long as you are receiving and sending data and your CRC checks are passing as expected.
    -Bharathi
