The LunchXL-F28027F is running ok when connecting with CCS5,but when I use InstaSPIN,it always stucks at Restarting at program Mpdel.... ,and can not go on. I have already copy the out file and renamed with appProgram.out.
Could you let me know what you see when you click on drop box beside "Connection: " It is shown as empty in your screen capture, there should be some entries in the drop down. If there are some entries could select "Texas Instruments XDS100v2 USB Emulator" and click Initialize Target?
If you do not see that could also enable tracing of GUI Composer Runtime and send/attach log file gets generated? Instructions on how to enable tracing are available at link below:
http://processors.wiki.ti.com/index.php/GUI_Composer/Tracing
You would need to specify -Dgc.webApp=InstaSPIN_F2802xF_UNIVERSAL parameter instead of what is shown on the wiki.
martin
Thank you,Martin!
I have done the trace,and get the all.log file below, can you help me to find out what the question is,by the way,I use ccs V5.3,is there may be some problem? Thank you
Install location:
file:/c:/ti/guicomposer/eclipse/
Configuration file:
file:/c:/ti/guicomposer/eclipse/configuration/config.ini loaded
Configuration location:
Framework located:
file:/c:/ti/guicomposer/eclipse/plugins/org.eclipse.osgi_3.8.1.v20120830-144521.jar
Framework classpath:
Splash location:
c:\ti\guicomposer\eclipse\plugins\com.ti.resource.explorer.rcp_2.0.0.201401262300\splash.bmp
Debug options:
file:/C:/ti/guicomposer/eclipse/traceAll.properties loaded
Time to load bundles: 31
Starting application: 734
[0823/205356:ERROR:gpu_info_collector_win.cc(91)] Can't retrieve a valid WinSAT assessment.
[0823/205356:ERROR:tcp_listen_socket.cc(72)] Could not bind socket to 127.0.0.1:4242
(1408798437437) GuiComposerWebServer.start(0)
Application Started: 3453
(1408798437500) GuiComposerWebServer.start(1)
(1408798437546) GuiComposerWebServer.start(2)
(1408798437562) GuiComposerWebServer.start(3)
(1408798437562) GuiComposerWebServer.start(4)
2014-08-23 20:53:57.562:INFO:oejs.Server:jetty-8.0.4.v20111024
2014-08-23 20:53:57.593:INFO:oejs.AbstractConnector:Started SelectChannelConnector@0.0.0.0:7273 STARTING
(1408798437609) GuiComposerWebServer.start(5)
(1408798437890) MyHandlerCollection.handle:(B)(GET /gc/webapp0/InstaSPIN_F2802xF_UNIVERSAL/index.html)@2190169 org.eclipse.jetty.server.Request@216b59
(1408798437906) MyHandlerCollection.handle:(E)[GET /gc/webapp0/InstaSPIN_F2802xF_UNIVERSAL/index.html]@2190169 org.eclipse.jetty.server.Request@216b59
(1408798438000) MyHandlerCollection.handle:(B)(GET /gc/webapp0/InstaSPIN_F2802xF_UNIVERSAL/lib/davinci.gc_1_2/WebContent/gc/templates/program/index.html?app_location_href=http://localhost:7273/gc/webapp0/InstaSPIN_F2802xF_UNIVERSAL/app.html&original_href=http://localhost:7273/gc/webapp0/InstaSPIN_F2802xF_UNIVERSAL/index.html&original_pathname=/gc/webapp0/InstaSPIN_F2802xF_UNIVERSAL/index.html)@2190169 org.eclipse.jetty.server.Request@216b59
(1408798438000) MyHandlerCollection.handle:(E)[GET /gc/webapp0/InstaSPIN_F2802xF_UNIVERSAL/lib/davinci.gc_1_2/WebContent/gc/templates/program/index.html?app_location_href=http://localhost:7273/gc/webapp0/InstaSPIN_F2802xF_UNIVERSAL/app.html&original_href=http://localhost:7273/gc/webapp0/InstaSPIN_F2802xF_UNIVERSAL/index.html&original_pathname=/gc/webapp0/InstaSPIN_F2802xF_UNIVERSAL/index.html]@2190169 org.eclipse.jetty.server.Request@216b59
(1408798438015) MyHandlerCollection.handle:(B)(GET /gc/webapp0/InstaSPIN_F2802xF_UNIVERSAL/lib/davinci.gc_1_2/WebContent/gc/dijit/libs/jquery/css/ui-darkness/jquery-ui.css)@2190169 org.eclipse.jetty.server.Request@216b59
(1408798438015) MyHandlerCollection.handle:(B)(GET /gc/webapp0/InstaSPIN_F2802xF_UNIVERSAL/lib/davinci.gc_1_2/WebContent/gc/templates/common/utils.js)@21975073 org.eclipse.jetty.server.Request@14f5021
(1408798438015) MyHandlerCollection.handle:(B)(GET /gc/webapp0/InstaSPIN_F2802xF_UNIVERSAL/lib/davinci.gc_1_2/WebContent/gc/dijit/libs/jquery/jquery-ui.min.js)@12280405 org.eclipse.jetty.server.Request@bb6255
(1408798438015) MyHandlerCollection.handle:(B)(GET /gc/webapp0/InstaSPIN_F2802xF_UNIVERSAL/lib/davinci.gc_1_2/WebContent/gc/dijit/libs/jquery/jquery.min.js)@19364400 org.eclipse.jetty.server.Request@1277a30
(1408798438015) MyHandlerCollection.handle:(E)[GET /gc/webapp0/InstaSPIN_F2802xF_UNIVERSAL/lib/davinci.gc_1_2/WebContent/gc/dijit/libs/jquery/css/ui-darkness/jquery-ui.css]@2190169 org.eclipse.jetty.server.Request@216b59
(1408798438015) MyHandlerCollection.handle:(E)[GET /gc/webapp0/InstaSPIN_F2802xF_UNIVERSAL/lib/davinci.gc_1_2/WebContent/gc/templates/common/utils.js]@21975073 org.eclipse.jetty.server.Request@14f5021
(1408798438015) MyHandlerCollection.handle:(E)[GET /gc/webapp0/InstaSPIN_F2802xF_UNIVERSAL/lib/davinci.gc_1_2/WebContent/gc/dijit/libs/jquery/jquery.min.js]@19364400 org.eclipse.jetty.server.Request@1277a30
(1408798438046) MyHandlerCollection.handle:(E)[GET /gc/webapp0/InstaSPIN_F2802xF_UNIVERSAL/lib/davinci.gc_1_2/WebContent/gc/dijit/libs/jquery/jquery-ui.min.js]@12280405 org.eclipse.jetty.server.Request@bb6255
(1408798438375) MyHandlerCollection.handle:(B)(GET /gc/webapp0/InstaSPIN_F2802xF_UNIVERSAL/lib/davinci.gc_1_2/WebContent/gc/dijit/libs/jquery/css/ui-darkness/images/ui-bg_inset-soft_30_f58400_1x100.png)@12280405 org.eclipse.jetty.server.Request@bb6255
(1408798438375) MyHandlerCollection.handle:(B)(GET /gc/webapp0/InstaSPIN_F2802xF_UNIVERSAL/lib/davinci.gc_1_2/WebContent/gc/dijit/libs/jquery/css/ui-darkness/images/ui-bg_inset-soft_25_000000_1x100.png)@21975073 org.eclipse.jetty.server.Request@14f5021
(1408798438375) MyHandlerCollection.handle:(B)(GET /gc/webapp0/InstaSPIN_F2802xF_UNIVERSAL/lib/davinci.gc_1_2/WebContent/gc/templates/common/images/pbar-ani.gif)@2190169 org.eclipse.jetty.server.Request@216b59
(1408798438375) MyHandlerCollection.handle:(B)(GET /gc/webapp0/InstaSPIN_F2802xF_UNIVERSAL/lib/davinci.gc_1_2/WebContent/gc/dijit/libs/jquery/css/ui-darkness/images/ui-bg_glass_20_555555_1x400.png)@19364400 org.eclipse.jetty.server.Request@1277a30
(1408798438375) MyHandlerCollection.handle:(E)[GET /gc/webapp0/InstaSPIN_F2802xF_UNIVERSAL/lib/davinci.gc_1_2/WebContent/gc/dijit/libs/jquery/css/ui-darkness/images/ui-bg_inset-soft_30_f58400_1x100.png]@12280405 org.eclipse.jetty.server.Request@bb6255
(1408798438375) MyHandlerCollection.handle:(E)[GET /gc/webapp0/InstaSPIN_F2802xF_UNIVERSAL/lib/davinci.gc_1_2/WebContent/gc/dijit/libs/jquery/css/ui-darkness/images/ui-bg_inset-soft_25_000000_1x100.png]@21975073 org.eclipse.jetty.server.Request@14f5021
(1408798438375) MyHandlerCollection.handle:(E)[GET /gc/webapp0/InstaSPIN_F2802xF_UNIVERSAL/lib/davinci.gc_1_2/WebContent/gc/templates/common/images/pbar-ani.gif]@2190169 org.eclipse.jetty.server.Request@216b59
(1408798438375) MyHandlerCollection.handle:(E)[GET /gc/webapp0/InstaSPIN_F2802xF_UNIVERSAL/lib/davinci.gc_1_2/WebContent/gc/dijit/libs/jquery/css/ui-darkness/images/ui-bg_glass_20_555555_1x400.png]@19364400 org.eclipse.jetty.server.Request@1277a30
(1408798438390) MyHandlerCollection.handle:(B)(GET /gc/webapp0/InstaSPIN_F2802xF_UNIVERSAL/lib/davinci.gc_1_2/WebContent/gc/templates/program/config.html?app_location_href=http://localhost:7273/gc/webapp0/InstaSPIN_F2802xF_UNIVERSAL/app.html&original_href=http://localhost:7273/gc/webapp0/InstaSPIN_F2802xF_UNIVERSAL/index.html&original_pathname=/gc/webapp0/InstaSPIN_F2802xF_UNIVERSAL/index.html)@2190169 org.eclipse.jetty.server.Request@216b59
(1408798438390) MyHandlerCollection.handle:(E)[GET /gc/webapp0/InstaSPIN_F2802xF_UNIVERSAL/lib/davinci.gc_1_2/WebContent/gc/templates/program/config.html?app_location_href=http://localhost:7273/gc/webapp0/InstaSPIN_F2802xF_UNIVERSAL/app.html&original_href=http://localhost:7273/gc/webapp0/InstaSPIN_F2802xF_UNIVERSAL/index.html&original_pathname=/gc/webapp0/InstaSPIN_F2802xF_UNIVERSAL/index.html]@2190169 org.eclipse.jetty.server.Request@216b59
(1408798438406) MyHandlerCollection.handle:(B)(GET /gc/webapp0/InstaSPIN_F2802xF_UNIVERSAL/lib/davinci.dojo_1_8/WebContent/dojo/dojo/dojo.js)@2190169 org.eclipse.jetty.server.Request@216b59
(1408798438406) MyHandlerCollection.handle:(B)(GET /gc/webapp0/InstaSPIN_F2802xF_UNIVERSAL/lib/davinci.gc_1_2/WebContent/gc/dijit/libs/jquery/css/jquery.combobox.css)@19364400 org.eclipse.jetty.server.Request@1277a30
(1408798438406) MyHandlerCollection.handle:(E)[GET /gc/webapp0/InstaSPIN_F2802xF_UNIVERSAL/lib/davinci.gc_1_2/WebContent/gc/dijit/libs/jquery/css/jquery.combobox.css]@19364400 org.eclipse.jetty.server.Request@1277a30
(1408798438406) MyHandlerCollection.handle:(E)[GET /gc/webapp0/InstaSPIN_F2802xF_UNIVERSAL/lib/davinci.dojo_1_8/WebContent/dojo/dojo/dojo.js]@2190169 org.eclipse.jetty.server.Request@216b59
(1408798438406) MyHandlerCollection.handle:(B)(GET /gc/webapp0/InstaSPIN_F2802xF_UNIVERSAL/lib/davinci.gc_1_2/WebContent/gc/backplane/guiComposer.js)@12280405 org.eclipse.jetty.server.Request@bb6255
(1408798438406) MyHandlerCollection.handle:(B)(GET /gc/webapp0/InstaSPIN_F2802xF_UNIVERSAL/lib/davinci.gc_1_2/WebContent/gc/dijit/libs/jquery/plugins/jquery.combobox.js)@21975073 org.eclipse.jetty.server.Request@14f5021
(1408798438406) MyHandlerCollection.handle:(E)[GET /gc/webapp0/InstaSPIN_F2802xF_UNIVERSAL/lib/davinci.gc_1_2/WebContent/gc/dijit/libs/jquery/plugins/jquery.combobox.js]@21975073 org.eclipse.jetty.server.Request@14f5021
(1408798438406) MyHandlerCollection.handle:(E)[GET /gc/webapp0/InstaSPIN_F2802xF_UNIVERSAL/lib/davinci.gc_1_2/WebContent/gc/backplane/guiComposer.js]@12280405 org.eclipse.jetty.server.Request@bb6255
(1408798438500) MyHandlerCollection.handle:(B)(GET /gc/webapp0/InstaSPIN_F2802xF_UNIVERSAL/appConfig.ccxml)@21975073 org.eclipse.jetty.server.Request@14f5021
(1408798438500) MyHandlerCollection.handle:(B)(GET /gc/webapp0/InstaSPIN_F2802xF_UNIVERSAL/lib/davinci.dojo_1_8/WebContent/dojo/dijit/Dialog.js)@12280405 org.eclipse.jetty.server.Request@bb6255
(1408798438500) MyHandlerCollection.handle:(E)[GET /gc/webapp0/InstaSPIN_F2802xF_UNIVERSAL/lib/davinci.dojo_1_8/WebContent/dojo/dijit/Dialog.js]@12280405 org.eclipse.jetty.server.Request@bb6255
(1408798438500) MyHandlerCollection.handle:(E)[GET /gc/webapp0/InstaSPIN_F2802xF_UNIVERSAL/appConfig.ccxml]@21975073 org.eclipse.jetty.server.Request@14f5021
(1408798438515) MyHandlerCollection.handle:(B)(GET /gc/webapp0/InstaSPIN_F2802xF_UNIVERSAL/lib/davinci.gc_1_2/WebContent/gc/dijit/libs/jquery/css/ui-darkness/images/ui-icons_cccccc_256x240.png)@12280405 org.eclipse.jetty.server.Request@bb6255
(1408798438515) MyHandlerCollection.handle:(B)(GET /gc/webapp0/InstaSPIN_F2802xF_UNIVERSAL/.appsettings)@21975073 org.eclipse.jetty.server.Request@14f5021
(1408798438515) MyHandlerCollection.handle:(E)[GET /gc/webapp0/InstaSPIN_F2802xF_UNIVERSAL/.appsettings]@21975073 org.eclipse.jetty.server.Request@14f5021
(1408798438515) MyHandlerCollection.handle:(E)[GET /gc/webapp0/InstaSPIN_F2802xF_UNIVERSAL/lib/davinci.gc_1_2/WebContent/gc/dijit/libs/jquery/css/ui-darkness/images/ui-icons_cccccc_256x240.png]@12280405 org.eclipse.jetty.server.Request@bb6255
(1408798438546) MyHandlerCollection.handle:(B)(GET /gc/webapp0/InstaSPIN_F2802xF_UNIVERSAL/lib/davinci.dojo_1_8/WebContent/dojo/dojo/window.js)@12280405 org.eclipse.jetty.server.Request@bb6255
(1408798438546) MyHandlerCollection.handle:(B)(GET /gc/webapp0/InstaSPIN_F2802xF_UNIVERSAL/lib/davinci.dojo_1_8/WebContent/dojo/dojo/dnd/Moveable.js)@21975073 org.eclipse.jetty.server.Request@14f5021
(1408798438546) MyHandlerCollection.handle:(B)(GET /gc/webapp0/InstaSPIN_F2802xF_UNIVERSAL/lib/davinci.dojo_1_8/WebContent/dojo/dojo/dnd/TimedMoveable.js)@2190169 org.eclipse.jetty.server.Request@216b59
(1408798438546) MyHandlerCollection.handle:(E)[GET /gc/webapp0/InstaSPIN_F2802xF_UNIVERSAL/lib/davinci.dojo_1_8/WebContent/dojo/dojo/dnd/Moveable.js]@21975073 org.eclipse.jetty.server.Request@14f5021
(1408798438546) MyHandlerCollection.handle:(E)[GET /gc/webapp0/InstaSPIN_F2802xF_UNIVERSAL/lib/davinci.dojo_1_8/WebContent/dojo/dojo/dnd/TimedMoveable.js]@2190169 org.eclipse.jetty.server.Request@216b59
(1408798438546) MyHandlerCollection.handle:(E)[GET /gc/webapp0/InstaSPIN_F2802xF_UNIVERSAL/lib/davinci.dojo_1_8/WebContent/dojo/dojo/window.js]@12280405 org.eclipse.jetty.server.Request@bb6255
(1408798438546) MyHandlerCollection.handle:(B)(GET /gc/webapp0/InstaSPIN_F2802xF_UNIVERSAL/lib/davinci.dojo_1_8/WebContent/dojo/dijit/focus.js)@19364400 org.eclipse.jetty.server.Request@1277a30
(1408798438546) MyHandlerCollection.handle:(B)(GET /gc/webapp0/InstaSPIN_F2802xF_UNIVERSAL/lib/davinci.dojo_1_8/WebContent/dojo/dijit/_base/manager.js)@8310913 org.eclipse.jetty.server.Request@7ed081
(1408798438546) MyHandlerCollection.handle:(B)(GET /gc/webapp0/InstaSPIN_F2802xF_UNIVERSAL/lib/davinci.dojo_1_8/WebContent/dojo/dijit/_Widget.js)@20052249 org.eclipse.jetty.server.Request@131f919
(1408798438546) MyHandlerCollection.handle:(E)[GET /gc/webapp0/InstaSPIN_F2802xF_UNIVERSAL/lib/davinci.dojo_1_8/WebContent/dojo/dijit/_base/manager.js]@8310913 org.eclipse.jetty.server.Request@7ed081
(1408798438546) MyHandlerCollection.handle:(E)[GET /gc/webapp0/InstaSPIN_F2802xF_UNIVERSAL/lib/davinci.dojo_1_8/WebContent/dojo/dijit/_Widget.js]@20052249 org.eclipse.jetty.server.Request@131f919
(1408798438546) MyHandlerCollection.handle:(E)[GET /gc/webapp0/InstaSPIN_F2802xF_UNIVERSAL/lib/davinci.dojo_1_8/WebContent/dojo/dijit/focus.js]@19364400 org.eclipse.jetty.server.Request@1277a30
(1408798438546) MyHandlerCollection.handle:(B)(GET /gc/webapp0/InstaSPIN_F2802xF_UNIVERSAL/lib/davinci.dojo_1_8/WebContent/dojo/dijit/_TemplatedMixin.js)@21975073 org.eclipse.jetty.server.Request@14f5021
(1408798438546) MyHandlerCollection.handle:(B)(GET /gc/webapp0/InstaSPIN_F2802xF_UNIVERSAL/lib/davinci.dojo_1_8/WebContent/dojo/dijit/_CssStateMixin.js)@2190169 org.eclipse.jetty.server.Request@216b59
(1408798438546) MyHandlerCollection.handle:(E)[GET /gc/webapp0/InstaSPIN_F2802xF_UNIVERSAL/lib/davinci.dojo_1_8/WebContent/dojo/dijit/_CssStateMixin.js]@2190169 org.eclipse.jetty.server.Request@216b59
(1408798438546) MyHandlerCollection.handle:(E)[GET /gc/webapp0/InstaSPIN_F2802xF_UNIVERSAL/lib/davinci.dojo_1_8/WebContent/dojo/dijit/_TemplatedMixin.js]@21975073 org.eclipse.jetty.server.Request@14f5021
(1408798438562) MyHandlerCollection.handle:(B)(GET /gc/webapp0/InstaSPIN_F2802xF_UNIVERSAL/lib/davinci.dojo_1_8/WebContent/dojo/dijit/form/_FormMixin.js)@12280405 org.eclipse.jetty.server.Request@bb6255
(1408798438562) MyHandlerCollection.handle:(B)(GET /gc/webapp0/InstaSPIN_F2802xF_UNIVERSAL/lib/davinci.dojo_1_8/WebContent/dojo/dijit/_DialogMixin.js)@8310913 org.eclipse.jetty.server.Request@7ed081
(1408798438562) MyHandlerCollection.handle:(B)(GET /gc/webapp0/InstaSPIN_F2802xF_UNIVERSAL/lib/davinci.dojo_1_8/WebContent/dojo/dijit/DialogUnderlay.js)@19364400 org.eclipse.jetty.server.Request@1277a30
(1408798438562) MyHandlerCollection.handle:(B)(GET /gc/webapp0/InstaSPIN_F2802xF_UNIVERSAL/lib/davinci.dojo_1_8/WebContent/dojo/dijit/layout/ContentPane.js)@20052249 org.eclipse.jetty.server.Request@131f919
(1408798438562) MyHandlerCollection.handle:(B)(GET /gc/webapp0/InstaSPIN_F2802xF_UNIVERSAL/lib/davinci.dojo_1_8/WebContent/dojo/dijit/nls/common.js)@2190169 org.eclipse.jetty.server.Request@216b59
(1408798438562) MyHandlerCollection.handle:(E)[GET /gc/webapp0/InstaSPIN_F2802xF_UNIVERSAL/lib/davinci.dojo_1_8/WebContent/dojo/dijit/layout/ContentPane.js]@20052249 org.eclipse.jetty.server.Request@131f919
(1408798438562) MyHandlerCollection.handle:(E)[GET /gc/webapp0/InstaSPIN_F2802xF_UNIVERSAL/lib/davinci.dojo_1_8/WebContent/dojo/dijit/_DialogMixin.js]@8310913 org.eclipse.jetty.server.Request@7ed081
(1408798438562) MyHandlerCollection.handle:(B)(GET /gc/webapp0/InstaSPIN_F2802xF_UNIVERSAL/lib/davinci.dojo_1_8/WebContent/dojo/dijit/main.js)@21975073 org.eclipse.jetty.server.Request@14f5021
(1408798438562) MyHandlerCollection.handle:(E)[GET /gc/webapp0/InstaSPIN_F2802xF_UNIVERSAL/lib/davinci.dojo_1_8/WebContent/dojo/dijit/form/_FormMixin.js]@12280405 org.eclipse.jetty.server.Request@bb6255
(1408798438562) MyHandlerCollection.handle:(E)[GET /gc/webapp0/InstaSPIN_F2802xF_UNIVERSAL/lib/davinci.dojo_1_8/WebContent/dojo/dijit/DialogUnderlay.js]@19364400 org.eclipse.jetty.server.Request@1277a30
(1408798438562) MyHandlerCollection.handle:(E)[GET /gc/webapp0/InstaSPIN_F2802xF_UNIVERSAL/lib/davinci.dojo_1_8/WebContent/dojo/dijit/nls/common.js]@2190169 org.eclipse.jetty.server.Request@216b59
(1408798438562) MyHandlerCollection.handle:(E)[GET /gc/webapp0/InstaSPIN_F2802xF_UNIVERSAL/lib/davinci.dojo_1_8/WebContent/dojo/dijit/main.js]@21975073 org.eclipse.jetty.server.Request@14f5021
(1408798438593) MyHandlerCollection.handle:(B)(GET /gc/webapp0/InstaSPIN_F2802xF_UNIVERSAL/lib/davinci.dojo_1_8/WebContent/dojo/dojo/dnd/common.js)@12280405 org.eclipse.jetty.server.Request@bb6255
(1408798438593) MyHandlerCollection.handle:(B)(GET /gc/webapp0/InstaSPIN_F2802xF_UNIVERSAL/lib/davinci.dojo_1_8/WebContent/dojo/dojo/touch.js)@20052249 org.eclipse.jetty.server.Request@131f919
(1408798438593) MyHandlerCollection.handle:(B)(GET /gc/webapp0/InstaSPIN_F2802xF_UNIVERSAL/lib/davinci.dojo_1_8/WebContent/dojo/dojo/dnd/Mover.js)@21975073 org.eclipse.jetty.server.Request@14f5021
(1408798438593) MyHandlerCollection.handle:(B)(GET /gc/webapp0/InstaSPIN_F2802xF_UNIVERSAL/lib/davinci.dojo_1_8/WebContent/dojo/dijit/registry.js)@2190169 org.eclipse.jetty.server.Request@216b59
(1408798438593) MyHandlerCollection.handle:(E)[GET /gc/webapp0/InstaSPIN_F2802xF_UNIVERSAL/lib/davinci.dojo_1_8/WebContent/dojo/dojo/dnd/common.js]@12280405 org.eclipse.jetty.server.Request@bb6255
(1408798438593) MyHandlerCollection.handle:(E)[GET /gc/webapp0/InstaSPIN_F2802xF_UNIVERSAL/lib/davinci.dojo_1_8/WebContent/dojo/dojo/touch.js]@20052249 org.eclipse.jetty.server.Request@131f919
(1408798438593) MyHandlerCollection.handle:(E)[GET /gc/webapp0/InstaSPIN_F2802xF_UNIVERSAL/lib/davinci.dojo_1_8/WebContent/dojo/dijit/registry.js]@2190169 org.eclipse.jetty.server.Request@216b59
(1408798438593) MyHandlerCollection.handle:(E)[GET /gc/webapp0/InstaSPIN_F2802xF_UNIVERSAL/lib/davinci.dojo_1_8/WebContent/dojo/dojo/dnd/Mover.js]@21975073 org.eclipse.jetty.server.Request@14f5021
(1408798438593) MyHandlerCollection.handle:(B)(GET /gc/webapp0/InstaSPIN_F2802xF_UNIVERSAL/lib/davinci.dojo_1_8/WebContent/dojo/dojo/Stateful.js)@2190169 org.eclipse.jetty.server.Request@216b59
(1408798438593) MyHandlerCollection.handle:(B)(GET /gc/webapp0/InstaSPIN_F2802xF_UNIVERSAL/lib/davinci.dojo_1_8/WebContent/dojo/dijit/a11y.js)@21975073 org.eclipse.jetty.server.Request@14f5021
(1408798438593) MyHandlerCollection.handle:(E)[GET /gc/webapp0/InstaSPIN_F2802xF_UNIVERSAL/lib/davinci.dojo_1_8/WebContent/dojo/dijit/a11y.js]@21975073 org.eclipse.jetty.server.Request@14f5021
(1408798438593) MyHandlerCollection.handle:(E)[GET /gc/webapp0/InstaSPIN_F2802xF_UNIVERSAL/lib/davinci.dojo_1_8/WebContent/dojo/dojo/Stateful.js]@2190169 org.eclipse.jetty.server.Request@216b59
(1408798438609) MyHandlerCollection.handle:(B)(GET /gc/webapp0/InstaSPIN_F2802xF_UNIVERSAL/lib/davinci.dojo_1_8/WebContent/dojo/dijit/_FocusMixin.js)@20052249 org.eclipse.jetty.server.Request@131f919
(1408798438609) MyHandlerCollection.handle:(B)(GET /gc/webapp0/InstaSPIN_F2802xF_UNIVERSAL/lib/davinci.dojo_1_8/WebContent/dojo/dijit/_OnDijitClickMixin.js)@21975073 org.eclipse.jetty.server.Request@14f5021
(1408798438609) MyHandlerCollection.handle:(B)(GET /gc/webapp0/InstaSPIN_F2802xF_UNIVERSAL/lib/davinci.dojo_1_8/WebContent/dojo/dijit/_WidgetBase.js)@2190169 org.eclipse.jetty.server.Request@216b59
(1408798438609) MyHandlerCollection.handle:(B)(GET /gc/webapp0/InstaSPIN_F2802xF_UNIVERSAL/lib/davinci.dojo_1_8/WebContent/dojo/dijit/hccss.js)@19364400 org.eclipse.jetty.server.Request@1277a30
(1408798438609) MyHandlerCollection.handle:(B)(GET /gc/webapp0/InstaSPIN_F2802xF_UNIVERSAL/lib/davinci.dojo_1_8/WebContent/dojo/dojo/uacss.js)@12280405 org.eclipse.jetty.server.Request@bb6255
(1408798438609) MyHandlerCollection.handle:(E)[GET /gc/webapp0/InstaSPIN_F2802xF_UNIVERSAL/lib/davinci.dojo_1_8/WebContent/dojo/dijit/hccss.js]@19364400 org.eclipse.jetty.server.Request@1277a30
(1408798438609) MyHandlerCollection.handle:(E)[GET /gc/webapp0/InstaSPIN_F2802xF_UNIVERSAL/lib/davinci.dojo_1_8/WebContent/dojo/dijit/_FocusMixin.js]@20052249 org.eclipse.jetty.server.Request@131f919
(1408798438609) MyHandlerCollection.handle:(E)[GET /gc/webapp0/InstaSPIN_F2802xF_UNIVERSAL/lib/davinci.dojo_1_8/WebContent/dojo/dijit/_WidgetBase.js]@2190169 org.eclipse.jetty.server.Request@216b59
(1408798438609) MyHandlerCollection.handle:(E)[GET /gc/webapp0/InstaSPIN_F2802xF_UNIVERSAL/lib/davinci.dojo_1_8/WebContent/dojo/dojo/uacss.js]@12280405 org.eclipse.jetty.server.Request@bb6255
(1408798438609) MyHandlerCollection.handle:(E)[GET /gc/webapp0/InstaSPIN_F2802xF_UNIVERSAL/lib/davinci.dojo_1_8/WebContent/dojo/dijit/_OnDijitClickMixin.js]@21975073 org.eclipse.jetty.server.Request@14f5021
(1408798438609) MyHandlerCollection.handle:(B)(GET /gc/webapp0/InstaSPIN_F2802xF_UNIVERSAL/lib/davinci.dojo_1_8/WebContent/dojo/dojo/string.js)@21975073 org.eclipse.jetty.server.Request@14f5021
(1408798438609) MyHandlerCollection.handle:(B)(GET /gc/webapp0/InstaSPIN_F2802xF_UNIVERSAL/lib/davinci.dojo_1_8/WebContent/dojo/dojo/cache.js)@2190169 org.eclipse.jetty.server.Request@216b59
(1408798438609) MyHandlerCollection.handle:(E)[GET /gc/webapp0/InstaSPIN_F2802xF_UNIVERSAL/lib/davinci.dojo_1_8/WebContent/dojo/dojo/string.js]@21975073 org.eclipse.jetty.server.Request@14f5021
(1408798438609) MyHandlerCollection.handle:(E)[GET /gc/webapp0/InstaSPIN_F2802xF_UNIVERSAL/lib/davinci.dojo_1_8/WebContent/dojo/dojo/cache.js]@2190169 org.eclipse.jetty.server.Request@216b59
(1408798438625) MyHandlerCollection.handle:(B)(GET /gc/webapp0/InstaSPIN_F2802xF_UNIVERSAL/lib/davinci.dojo_1_8/WebContent/dojo/dijit/BackgroundIframe.js)@2190169 org.eclipse.jetty.server.Request@216b59
(1408798438625) MyHandlerCollection.handle:(E)[GET /gc/webapp0/InstaSPIN_F2802xF_UNIVERSAL/lib/davinci.dojo_1_8/WebContent/dojo/dijit/BackgroundIframe.js]@2190169 org.eclipse.jetty.server.Request@216b59
(1408798438625) MyHandlerCollection.handle:(B)(GET /gc/webapp0/InstaSPIN_F2802xF_UNIVERSAL/lib/davinci.dojo_1_8/WebContent/dojo/dijit/_Container.js)@2190169 org.eclipse.jetty.server.Request@216b59
(1408798438625) MyHandlerCollection.handle:(B)(GET /gc/webapp0/InstaSPIN_F2802xF_UNIVERSAL/lib/davinci.dojo_1_8/WebContent/dojo/dijit/layout/_ContentPaneResizeMixin.js)@21975073 org.eclipse.jetty.server.Request@14f5021
(1408798438625) MyHandlerCollection.handle:(B)(GET /gc/webapp0/InstaSPIN_F2802xF_UNIVERSAL/lib/davinci.dojo_1_8/WebContent/dojo/dojo/html.js)@12280405 org.eclipse.jetty.server.Request@bb6255
(1408798438625) MyHandlerCollection.handle:(B)(GET /gc/webapp0/InstaSPIN_F2802xF_UNIVERSAL/lib/davinci.dojo_1_8/WebContent/dojo/dijit/nls/loading.js)@20052249 org.eclipse.jetty.server.Request@131f919
(1408798438640) MyHandlerCollection.handle:(E)[GET /gc/webapp0/InstaSPIN_F2802xF_UNIVERSAL/lib/davinci.dojo_1_8/WebContent/dojo/dijit/_Container.js]@2190169 org.eclipse.jetty.server.Request@216b59
(1408798438640) MyHandlerCollection.handle:(B)(GET /gc/webapp0/InstaSPIN_F2802xF_UNIVERSAL/lib/davinci.dojo_1_8/WebContent/dojo/dojo/dnd/autoscroll.js)@19364400 org.eclipse.jetty.server.Request@1277a30
(1408798438640) MyHandlerCollection.handle:(B)(GET /gc/webapp0/InstaSPIN_F2802xF_UNIVERSAL/lib/davinci.dojo_1_8/WebContent/dojo/dojo/hccss.js)@8310913 org.eclipse.jetty.server.Request@7ed081
(1408798438640) MyHandlerCollection.handle:(B)(GET /gc/webapp0/InstaSPIN_F2802xF_UNIVERSAL/lib/davinci.dojo_1_8/WebContent/dojo/dijit/Destroyable.js)@2190169 org.eclipse.jetty.server.Request@216b59
(1408798438640) MyHandlerCollection.handle:(E)[GET /gc/webapp0/InstaSPIN_F2802xF_UNIVERSAL/lib/davinci.dojo_1_8/WebContent/dojo/dijit/layout/_ContentPaneResizeMixin.js]@21975073 org.eclipse.jetty.server.Request@14f5021
(1408798438640) MyHandlerCollection.handle:(B)(GET /gc/webapp0/InstaSPIN_F2802xF_UNIVERSAL/lib/davinci.dojo_1_8/WebContent/dojo/dijit/a11yclick.js)@21975073 org.eclipse.jetty.server.Request@14f5021
(1408798438640) MyHandlerCollection.handle:(E)[GET /gc/webapp0/InstaSPIN_F2802xF_UNIVERSAL/lib/davinci.dojo_1_8/WebContent/dojo/dojo/html.js]@12280405 org.eclipse.jetty.server.Request@bb6255
(1408798438640) MyHandlerCollection.handle:(E)[GET /gc/webapp0/InstaSPIN_F2802xF_UNIVERSAL/lib/davinci.dojo_1_8/WebContent/dojo/dojo/hccss.js]@8310913 org.eclipse.jetty.server.Request@7ed081
(1408798438640) MyHandlerCollection.handle:(B)(GET /gc/webapp0/InstaSPIN_F2802xF_UNIVERSAL/lib/davinci.dojo_1_8/WebContent/dojo/dijit/Viewport.js)@12280405 org.eclipse.jetty.server.Request@bb6255
(1408798438640) MyHandlerCollection.handle:(E)[GET /gc/webapp0/InstaSPIN_F2802xF_UNIVERSAL/lib/davinci.dojo_1_8/WebContent/dojo/dojo/dnd/autoscroll.js]@19364400 org.eclipse.jetty.server.Request@1277a30
(1408798438640) MyHandlerCollection.handle:(E)[GET /gc/webapp0/InstaSPIN_F2802xF_UNIVERSAL/lib/davinci.dojo_1_8/WebContent/dojo/dijit/nls/loading.js]@20052249 org.eclipse.jetty.server.Request@131f919
(1408798438640) MyHandlerCollection.handle:(E)[GET /gc/webapp0/InstaSPIN_F2802xF_UNIVERSAL/lib/davinci.dojo_1_8/WebContent/dojo/dijit/Viewport.js]@12280405 org.eclipse.jetty.server.Request@bb6255
(1408798438640) MyHandlerCollection.handle:(E)[GET /gc/webapp0/InstaSPIN_F2802xF_UNIVERSAL/lib/davinci.dojo_1_8/WebContent/dojo/dijit/a11yclick.js]@21975073 org.eclipse.jetty.server.Request@14f5021
(1408798438640) MyHandlerCollection.handle:(E)[GET /gc/webapp0/InstaSPIN_F2802xF_UNIVERSAL/lib/davinci.dojo_1_8/WebContent/dojo/dijit/Destroyable.js]@2190169 org.eclipse.jetty.server.Request@216b59
(1408798438640) MyHandlerCollection.handle:(B)(GET /gc/webapp0/InstaSPIN_F2802xF_UNIVERSAL/lib/davinci.dojo_1_8/WebContent/dojo/dijit/layout/utils.js)@8310913 org.eclipse.jetty.server.Request@7ed081
(1408798438640) MyHandlerCollection.handle:(E)[GET /gc/webapp0/InstaSPIN_F2802xF_UNIVERSAL/lib/davinci.dojo_1_8/WebContent/dojo/dijit/layout/utils.js]@8310913 org.eclipse.jetty.server.Request@7ed081
(1408798438640) MyHandlerCollection.handle:(B)(GET /gc/webapp0/InstaSPIN_F2802xF_UNIVERSAL/lib/davinci.dojo_1_8/WebContent/dojo/dojo/parser.js)@19364400 org.eclipse.jetty.server.Request@1277a30
(1408798438656) MyHandlerCollection.handle:(E)[GET /gc/webapp0/InstaSPIN_F2802xF_UNIVERSAL/lib/davinci.dojo_1_8/WebContent/dojo/dojo/parser.js]@19364400 org.eclipse.jetty.server.Request@1277a30
(1408798438671) MyHandlerCollection.handle:(B)(GET /gc/webapp0/InstaSPIN_F2802xF_UNIVERSAL/lib/davinci.dojo_1_8/WebContent/dojo/dojo/date/stamp.js)@8310913 org.eclipse.jetty.server.Request@7ed081
(1408798438671) MyHandlerCollection.handle:(B)(GET /gc/webapp0/InstaSPIN_F2802xF_UNIVERSAL/lib/davinci.dojo_1_8/WebContent/dojo/dojo/_base/url.js)@19364400 org.eclipse.jetty.server.Request@1277a30
(1408798438671) MyHandlerCollection.handle:(E)[GET /gc/webapp0/InstaSPIN_F2802xF_UNIVERSAL/lib/davinci.dojo_1_8/WebContent/dojo/dojo/date/stamp.js]@8310913 org.eclipse.jetty.server.Request@7ed081
(1408798438671) MyHandlerCollection.handle:(E)[GET /gc/webapp0/InstaSPIN_F2802xF_UNIVERSAL/lib/davinci.dojo_1_8/WebContent/dojo/dojo/_base/url.js]@19364400 org.eclipse.jetty.server.Request@1277a30
(1408798438671) MyHandlerCollection.handle:(B)(GET /gc/webapp0/InstaSPIN_F2802xF_UNIVERSAL/lib/davinci.dojo_1_8/WebContent/dojo/dojo/resources/blank.gif)@19364400 org.eclipse.jetty.server.Request@1277a30
(1408798438671) MyHandlerCollection.handle:(E)[GET /gc/webapp0/InstaSPIN_F2802xF_UNIVERSAL/lib/davinci.dojo_1_8/WebContent/dojo/dojo/resources/blank.gif]@19364400 org.eclipse.jetty.server.Request@1277a30
(1408798438687) MyHandlerCollection.handle:(B)(GET /gc/webapp0/InstaSPIN_F2802xF_UNIVERSAL/index.json)@19364400 org.eclipse.jetty.server.Request@1277a30
(1408798438687) MyHandlerCollection.handle:(E)[GET /gc/webapp0/InstaSPIN_F2802xF_UNIVERSAL/index.json]@19364400 org.eclipse.jetty.server.Request@1277a30
(1408798438703) MyHandlerCollection.handle:(B)(GET /ws/)@6711891 org.eclipse.jetty.server.Request@666a53
(1408798438703) ---new connection=WSFrameConnectionD13@127.0.0.1:7273<->127.0.0.1:4493
(1408798438718) MyHandlerCollection.handle:(E)(GET /ws/)@6711891 org.eclipse.jetty.server.Request@666a53
(1408798438718) ---sending ping
(1408798438984) ---Received from Client={"requestName":"setInitInfo","gcLibraryVersion":{"major":1,"minor":2,"revision":0,"path":"davinci.gc_1_2","name":"1.2.0"},"documentVersion":{"name":"1.2.0000","major":1,"minor":2},"href":"http://localhost:7273/gc/webapp0/InstaSPIN_F2802xF_UNIVERSAL/index.html"}
(1408798439046) GuiComposerWebSocket:---Received from Client={"requestName":"addWidgetBindings","widgetBindings":[{"widgetId":"appConsole","propertyName":"value","serverBindName":"value:pm.$logger.last_message","options":{"dataType":"String","defaultValue":null}},{"widgetId":"progressTask","propertyName":"value","serverBindName":"value:pm.$progress.taskName","options":{"dataType":"String","defaultValue":null}},{"widgetId":"progressPercentage","propertyName":"value","serverBindName":"value:pm.$progress.percent","options":{"dataType":"Integer","defaultValue":null}},{"widgetId":"targetConnections","propertyName":"value","serverBindName":"pm.$target.connections","options":{"dataType":"Array","defaultValue":null}}]}
(1408798439046) listeners_count:WebWidgetErrorBind[widget.backplane].addChangedListener(1)
(1408798439046) GuiComposerWebSocket:---Received bindings for widgetId =appConsole propertyName=value serverBindName=value:pm.$logger.last_message
(1408798439046) listeners_count:StockBind[value:backplane.$last_critical_error].addChangedListener(1)
(1408798439046) GuiComposerWebSocket:---Received bindings for widgetId =progressTask propertyName=value serverBindName=value:pm.$progress.taskName
(1408798439046) GuiComposerWebSocket:---Received bindings for widgetId =progressPercentage propertyName=value serverBindName=value:pm.$progress.percent
(1408798439046) GuiComposerWebSocket:---Received bindings for widgetId =targetConnections propertyName=value serverBindName=pm.$target.connections
(1408798439046) GuiComposerWebSocket:---Received from Client={"requestName":"executeOperation","operationName":"value:pm.$init","arguments":{"connection":"Texas Instruments XDS100v2 USB Emulator","device":"TMS320F28027","appPath":"/gc/webapp0/InstaSPIN_F2802xF_UNIVERSAL/index.html"},"requestId":"1"}
(1408798439046) listeners_count:DSBaseValueBind[null].addChangedListener(1)
(1408798439062) GuiComposerWebSocket:---Received from Client={"requestName":"pingReply"}
(1408798439078) on_value_changed:DSTargetConnectionsBind[null].value=[]
(1408798439078) listeners_count:WebWidgetValueBind[widget.appConsole.value].addChangedListener(1)
(1408798439078) listeners_count:StockBind[value:pm.$logger.last_message].addChangedListener(1)
(1408798439078) listeners_count:WebWidgetValueBind[widget.progressTask.value].addChangedListener(1)
(1408798439078) listeners_count:StockBind[value:pm.$progress.taskName].addChangedListener(1)
(1408798439078) listeners_count:WebWidgetValueBind[widget.progressPercentage.value].addChangedListener(1)
(1408798439078) listeners_count:StockBind[value:pm.$progress.percent].addChangedListener(1)
java.lang.UnsatisfiedLinkError: C:\ti\guicomposer\ccs_base\common\bin\fsutiljni.dll: Can't find dependent libraries
at java.lang.ClassLoader$NativeLibrary.load(Native Method)
at java.lang.ClassLoader.loadLibrary0(Unknown Source)
at java.lang.ClassLoader.loadLibrary(Unknown Source)
at java.lang.Runtime.load0(Unknown Source)
at java.lang.System.load(Unknown Source)
at com.ti.debug.engine.xpcom.Runtime.getFSUtil(Runtime.java:46)
at com.ti.utility.filesystem.DirectoryService.<init>(DirectoryService.java:21)
at com.ti.utility.filesystem.DirectoryService.instance(DirectoryService.java:33)
at com.ti.debug.engine.scripting.TargetConfigurationGenerator.<init>(TargetConfigurationGenerator.java:68)
at com.ti.debug.engine.scripting.DebugServer.createTargetConfigurationGenerator(DebugServer.java:1621)
at com.ti.binding.program.internal.DSInitRunBind.generateConfigFile(DSInitRunBind.java:209)
at com.ti.binding.program.internal.DSInitRunBind.run(DSInitRunBind.java:141)
at com.ti.gui.composer.common.internal.WebBindingRegistry$WebClientData$ServerListener$2.run(WebBindingRegistry.java:163)
at com.ti.backplane.internal.bind.DefaultRealm$ReportingRunnable.run(DefaultRealm.java:26)
at java.util.concurrent.Executors$RunnableAdapter.call(Unknown Source)
at java.util.concurrent.FutureTask$Sync.innerRun(Unknown Source)
at java.util.concurrent.FutureTask.run(Unknown Source)
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$301(Unknown Source)
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(Unknown Source)
at java.util.concurrent.ThreadPoolExecutor$Worker.runTask(Unknown Source)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
at java.lang.Thread.run(Unknown Source)
(1408798439093) listeners_count:WebWidgetValueBind[widget.targetConnections.value].addChangedListener(1)
(1408798439093) listeners_count:DSTargetConnectionsBind[pm.$target.connections].addChangedListener(1)
(1408798439109) Sending to client:{"requestName" : "propertyChange" , "widgetId" : "targetConnections" , "propertyName" : "value" , "timeSent" : 1408798439109 , "newValue" : [] }
(1408798439125) Sending to client:{"requestName" : "propertyChange" , "widgetId" : "appConsole" , "propertyName" : "value" , "timeSent" : 1408798439125 , "newValue" : "Restarting Program Model...\n" }
(1408798498718) GuiComposerWebSocket:---sending ping
(1408798498718) GuiComposerWebSocket:---Received from Client={"requestName":"pingReply"}
(1408798510203) GuiComposerWebSocket:---connection WSFrameConnectionD13@127.0.0.1:7273<->127.0.0.1:4493 closed after 71 seconds
fyi.... I found a bug in the installer that most likely caused this issue. One of required msvc library installers is not being run. Installing CCSv5.5 is one way of getting around this problem. Than you for your post.
Martin
