when i follow the "Lab Procedure" of proj_lab13c (in instaspin_labs.pdf ); it says:
“At the conclusion of the motion sequence “gMotorVars.SpinTAC.PosPlanDone” will be set to 1. This is done to indicate to the user program that the motion sequence has completed.”
but i did not found struct member "PosPlanDone" in struct _ST_Vars_t !
Is the member var "PosPlanDone" abandoned from “struct _ST_Vars_t” @ the last version code?
and how can i konw whether the posplan is done?
