Other Parts Discussed in Thread: LP8860-Q1,
Dears,
Could you kindly help tell me what's different between LP8863A/B/C/D/H/C/J/L/N/R? I can't find any different with each other on the datasheet. Thanks!
Jacking
Hello Jacking:
I believe your question is regarding LP8860-Q1 and not LP8863-Q1 as LP8863-Q1 does not have all these versions you have mentioned.
LP8860 has programmable eeprom register and these various versions i.e. LP8860 A/B/C etc. signifies different default register programming. Actual physical device is same but different eeprom programming. The link below is a .pdf document that spells out the differences between different eeprom versions.
Hope this clarifies it but please let me know if there are any questions.
Liaqat
