  • Resolved
[FAQ] TPS65381A-Q1: Tool to calculate the watchdog and MCU ESM settings and validate their timing with respect to the MCU programmed timing?
Mastermind 18700 points
Part Number: TPS65381A-Q1
Is there a tool to calculate the watchdog and MCU ESM settings and validate their timing with respect to the MCU programmed timing?
Scott Monroe
For more information on Multi-Channel Power Management ICs:
Find the right power solution for your processor or FPGA. Visit www.ti.com/SoCPower today!
  • Attached is a spreadsheet to aid in calculations for the watchdog and MCU ESM module of the TPS65381A-Q1.
    2287.TPS65381A-Q1 Watchdog and MCU ESM Calculator - FAQ - E2E.xlsx
    Customer entered data is in the yellow highlighted cells with blue font.
    MCU ESM Calculator:
    • TMS570 Mode:   will calculate detected low time on the ERROR/WDI pin.  Customer enters register setting as a HEX value and the spreadsheet will calculate the low time minimum and maximum to detect a MCU error from its error signal.
    • PWM Mode:   will calculate low time and the high time on the ERROR/WDI pin.  Customer enters register setting as a HEX value and the spreadsheet will calculate the minimum and maximum times to detect a MCU error from its error signal.
    Watchdog Calculator:
    • Both Modes:
      • Window 1 and Window 2 minimum and maximum value calculations from customer entered register values (HEX).
      • Customer enters target minimum watchdog fail count their software will decrement the WD_FAIL_CNT to so that the minimum and maximum time to ENDRV going low (ENABLE_DRV = 1) and then NRES going low (RESET state transition while WD_RST_EN = 1) based on the targeted minimum WD_FAIL_CNT and settings for Window 1 and Window 2.
    • Trigger Mode:
      • MCU clock timing and tolerance is entered by customer.
      • Spreadsheet confirms with MCU timing and tolerance and watchdog settings for TPS65381A-Q1 if the settings for the watchdog will create good events in the known valid trigger time.
    • Q&A Mode:
      • MCU clock timing, tolerance and MCU answer times is entered by customer
    Scott Monroe
