We found the current into BAT Pin is about 14μA to 12μA.No load on OUT pin or light load on OUT pin.
But as DS,it's 6.5 μA max.
Is there any suggestion? Thank you.
Hi
Nope.I tested this on my PCB.Not EVM.
F1 is a PTC Resettable Fuse.
About the test procedure:
We have design a small PCB to test the circuit,like the attatched image.
option 1:
Battery=Li-Po battery.
IN PIN NO conection.OUT PIN No conection.
CE = Low
all the time,
CHG and PG were floating,no conection.
We use a multimeter to measure the battery + between BAT PIN.
option2:
CE = Low
all the time,
CHG and PG were conected to LEDS,and attached the circuit.
