Hello TI,
I am currently testing BQ2000 Evalution kit for charging 3 Ni MH cells in series. As described in testing procedure, Top-off mode is selected and jumper on "Y" for 160 timeout. 200 K-Ohm resistor was soldered on board for 3 Ni-MH cells and jumper was put on that. We supplied board by 12 V DC input. All set up was done as described in datasheet page 3 (Section 2.3). While testing problem i found is that: LED on board is always blinking. How come? When batteries are being charged by Eval kit, LED should be on Low or? am i missing any important configuration on Board?
What could be your suggestion or solution for charging 3 Ni-mH cells in series?
