Other Parts Discussed in Thread: LMG3410R070, LMG3410R050, DRV421, INA253EVM
Hello
LMG3410R050 and LMG3410R070 have different resistances and hence, I guess, allow different currents. My questions are;
· The daughter boards of these Power switches both have a rating of 8Amp. In that case what is the difference between the two daughter boards? Response time of the power switch? If not what is the difference?
· Is the 8Amp limit arises from the daughter board or the inductors of the mother board?
· If it is motherboard limitation and we do not use this mother board what is the current limit of each of these 2 daughter boards then?
· It is said that the motherboard measures the GaN switching....please explain to us what does measuring switching mean? Is it measuring the time of the switching, the voltage during switching, the current during switching ....etc ?
· The motherboard does not seem to be useful if we want to test closed-loop performance of the daughter board......do you have a product or reference design that we can use if want to test closed loop performance?
· If we want to use the daughter boards alone....do you have any product or reference design to measure the currents and/or the voltages (AC side and/or DC side of the leg)?
Sam
