  • TI Thinks Resolved
[FAQ] BQ25100: Can BQ25100 be enabled and disabled by TS pin?
Genius 3125 points
Part Number: BQ25100
Customer wants to use 230mAh battery without NTC thermistor.
And wants to make enable and disable function by using TS pin.
If possible, could you let me know how can make it?
Nicky
  • Hello Nicky
    This can be done.
    If no NTC thermistor is used the TS pin should be connected to a 10k resistor to ground.  This will be a safe condition for the temp sensing function.
    To disable the device pull TS pin low, directly to ground.
    Note that TS pin is a current source and the 10k resistor will develop a voltage.
    Bill Johns,  Applications Engineer
    Texas Instruments Inc
    Dallas, Texas
    For more information on Battery Charger Solutions see Link
    Search "FAQ" on E2E Forum for common questions on battery charger solutions.
