Hi Support Team
Would you please help check the below question about TPS2549-Q1 application
1, What will happen when the pin 12(OUT) short to GND. And the Vout can restore to 5v immediately or delay the fixed time when remove the fault
2, Customer had found the Vout is about 0-0.5V when the the pin 12(OUT) short to GND when the test. But there has a little Vout is about 0.9-1V also thatt customer don't hope to see
Please help give us some advice and explain the short circuit protection mechanism of TPS2549-Q1
