Now my customer is considering bq76PL455A and then they have some concern as below. Can you see it and give your opinion?
[Situation]
Customer would like to daisy-chain PL455As but they are not located in the same chassis so COMMH/L lines should be connected via connector and cable. Then they have concern if this may not be recommended because the communication error will be happened due to EMI noise to cable in noisy environment.
[Question]
Then, can you recommend such use case and share the example of cable or connector for COMMH/L lines?
Satoshi / Japan Disty
