I created a schematic and board layout in Eagle using the BQ24650 IC. In the reference design, some components had an analog ground and a digital ground. I decided to connect all of them to analog ground and create a 2 layer board with ground planes on the top and bottom layer. Will the circuit still operate properly if it is connected this way? I noticed the EVM version created by TI used 4 layers. Is there a specific reason?
Here are the files:
Schematic:
PCB Layout:
Also, here are some pictures of the schematic and the board.
Thanks.
