What pins are active in the bq769x0 during shutdown? Are the CAPx pins low to their respective references? I assume REGOUT would be off.
I'm going to use the bq76930, but I need a way to wake it up using a charge voltage instead of a switch. I was going to use one of the pins as a signal to disable my TS1 pull-up circuit if the AFE is already awake. Please let me know if you have a circuit that works.
Thanks in advance.
