On page 63 of SLUA404, Configuration describes an alternative method for setting TDA, FD, purely using voltage measurements. How do I disable this method - I don't need it?
Thank you,
Jeremy.
Thank you,
Jeremy.
Thanks Mike - that seems to work for the % thresholds, but not for the TDA/FD Set Volt and TDA/FD Clear Volt thresholds. However, I figure that setting these to 0V and 16800mV respectively is as good as disabling it. Does that seem right to you?
Jeremy.
