Dear Members,
I am trying to use the BQ7694000 and BQ78350 companion chip with dsPIC33EP512MU810. I am using dsPIC33E to talk to the companion chip over SMBus. What i am planning to do is to talk to the companion chip using dsPIC33E to poll information such as 3 Temp Sensors, Register information to read and to write and so on. What i see different to the BQStudio is that there are no sufficient commands available in the datasheet to replicate what information is polled through the BQStudio to be same done using the dsPIC33E micro controller. Is there any other list of special commands that i can you use ? Your quick reply or reply ASAP will be very much appreciated.
Thank You Very Much
