Hi Sir,
I found that the SoC sometimes rise or fall suddenly with constant charging/discharging, here are the datalog:
Could you please help on it, thank you.
Hi Sir,
Hi Terry,
Yes, it was done already, and this is RMA issue from customer.
As I know, if learning cycle not done yet, the SoC will not really accurate. But in this case, I see data discontinue everywhere(temp.,FullAveCap,MaxLoadCurrent,StandbyCurrent...). It's not result in cycly learning or chem ID, am I right?
How could I explain those discontinue data from the datalog?
Thank you very much.
Hi Terry,
The testing is under constant temperture and current condition. It's not only happened at temp parameter, but also FullAveCap, MaxLoadCurrent, StandbyCurrent, etc.
Is this happened before?
How the value NomAvailCap and RemCap be calculated? Is there any formula?
Thank you.
