WHAT IS THE ADVANTAGE OF RCD RESET FORWARD CONVERTER OVER OTHER RESET TECHNIQUES.
Is there a particular device part number you are interested in? It is always best if you include the part number in the title of your post.
john tucker,
any particular advantage that is unique to RCD RESET FORWARD CONVERTER compared to other types of reset technique.
when size is the constraint while designing a forward converter greater than 100W, it's better to use RCD reset FORWARD CONVERTER..
RIGHT?
I do not personally have those equations. I primarily work with non-isolated buck converters and have never designed a forward converter using RCD clamp. Perhaps someone else can provide them.
