Team,
My customer, key power automation in China is now using our UC2844. They use two-transistor forward with our UC2844, below is the principle of the topology:
With this topology, customer tested it and found that the output voltage will drop about 20% when the load current changed from 0 to full load suddenly, it seems the load transient is not good. Do you have some suggestion or solution for solving this problem? Thanks a lot for your support!
Sulyn Zhang
