Hi Team,
Our customer would like to make the following sequences using the trigger function.
[Sequences]
1.TRIG pin is toggled from High to Low.
2.RGB repeats blinking.
3.It is stop if TRIG pin is toggled from Low to High.
I understand that they can use this sequence.
However, could you please let us know if you have any concern and other recommended Stop method?
(For example, Is "the control of OP_MODE register" better to stop it?)
Kanemaru
