Has anyone ever tried to parallel the LM3410? I would like to use 2 in parallel to get higher output current. Are there any tips or suggestions for getting the two drivers to share the load somewhat equally?
Hi Andrew,
It is not a good idea to parallel two devices as they may switch on/off at slightly different times and the result will be a huge amount of errant switching. Would you please let me know the spec of your application? Using a controller may be an good idea to get higher output current.
Victor
I have 3-4V input, and I want 19V output at 1A. Are there other controllers you can recommend?
Actually one LM3410 can fulfill your requirement. You may use the schematic on LM3410 data sheet pg.33 as a reference.
Victor
But the internal switch can only handle 3A. To boost from 3V to 18V out, you need the internal switch to handle up to 6A to get 1A out.
