I have an A7800 series voltage regulator and want to ensure it is clean as possible. I noticed your simplified schematic number 4 from the data sheet that shows the use of capacitors. I am trying to utilize this in an op-amp circuit that requires up to 5MHz output and would like to know if this regulator will be able to maintain that frequency. Will these capacitors maintain 5 MHz? If not, what do you recommend?
Lee
831-656-2327
