We are using a couple of the TPS63060's in our design. Unfortunately, they are all pulling 50uA in shutdown. They should be less than 2uA each. The Enable pin is driven low, and the pin is definitely not floating. This has a significantly impact on our battery life as our device spends quite a bit of time in a very low power state.
Is this a known issue, or is there something that could cause this to happen? We are seeing the same thing on all of our prototypes.
Thank you,
Jamaal
