Hi
Does anyone have the variation data for TPS54040A Boot UVLO threthold voltage?
Go
Hi, Anthony
Thank you for your comment.
My customer'd like to know the target voltage difference between Vin and Vout
which can avoid the behavior described in TPS54040A D/S page13
"Low Dropout Operation and Bootstrap Voltage (BOOT)".
Go
Hi Go,
I found the data and it suggests a maximum value of 2.4V.
The extreme occurs at -40 deg C as should be suggested by Figure 21 in the datasheet. It seems the Y axis had it's numbers reversed based on the data I looked over and other datasheets in this family. The correct curve could be found in the TPS54060A datasheet.
Anthony
