TPS65233 how to make 44kHz tone signal
Other Parts Discussed in Thread: TPS65233
Dear TI
Customer is asking how to make 44kHz tone signal  of TPS65233.
Do you have any reference circuit  to make 44kHz tone signal?
Please conntact  to below address.
narisawa-k@clv.macnica.co.jp
Thank you your cooperation
Best Regards
K.Narisawa
    Basically, TPS65233 can't generate 44kHz tone signal itself. The only option is to apply the 44kHz tone signal(generated by MCU or SoC) on EXTM, TPS65233 will sync with EXTM to generate 44kHz tone.
    Well, TPS65233 LNB output tone has 10us for each rising and falling time when tone exists. 44kHz tone is approaching the frequency limit. I have double checked the 44kHz tone application, the LNB tone output will be triangle.  Please double check if the 44kHz tone is necessary.
    Jennifer
