Other Parts Discussed in Thread: LM5116
Dear Sir/Madam,
I am working on a project to develop regulated power supply for the laboratory application. In my design, I am using the buck controller IC LM25116, which has high HO, Low drive LO and a switch SW pins. But in my design, I am using push pull amplifier circuit to drive the high side of the n-channel MOSFET and for the protection I have used pulse transformer after the push pull circuit and then from the pulse transformer to the gate drive of the MOSFET. So, here I need to use only the HO pin from the controller and I do not know how the other pins are connected. It would be great and thankful to you for the answer in advance.
With kind regards,
Swetha
