Voltage droops in a moment when Sandisk USB memory is inserted and voltage drop exceeds customer application's tolerance.
Do you have an experiance like above case?
FYI, when customer uses current limit IC BD82032 from Rohm, voltage doesn't droop.
Difference between TPS2069C and BD82032 is package.
TPS2069C is 6 pin package and BD82032 is 8 pin package.
Thanks in advance.
