TM4C1294NCPDT PoE Design
Other Parts Discussed in Thread: TM4C1294NCPDT, TPS2375EVM, TPS2375, TPS23750, TM4C129ENCPDT, TPS23753A
Hi All,
I have made a custom design with TM4C1294NCPDT and TPS2375PW-1. I tried to combine the reference designs found in their datasheets.
But it seems that I made a principle design mistake, as it sporadically worked and didn't work, and after a while the MCU became faulty.
The symptoms were the following:
  • During startup there were some small sparks (only noticeable in the dark) at the Ethernet pins of the MCU.
  • The MCU was heating with the udpEcho / tcpEcho samples.
  • The Ethernet link LEDs lit, but The DHCP communication was sporadically faulty.
Below are the design parts which I think contain the mistake (the power supply parts worked fine):
  • RJ45 connector side of the LAN transformer:
  • The MCU side of the LAN transformer:
(Note that the TX+/TX- nets are connected to TD+/TD- and the RX+/RX- nets are connected to RD+/RD-n, and GND isconnected to PGND )
Could someone please take a look at the design and tell what's wrong? I would be very grateful.
Thank you,
Gergely
