Simulation parameter of CSD97370Q5M
Other Parts Discussed in Thread: CSD97370Q5M
I am trying to do MATLAB simulation on control of CSD97370Q5M with controller I designed. Therefore, I will need to have the parameters of the mosfet to calculate the power lost on device and efficiency. Is there a way to get the parameter of this device or which device with those parameter on their datasheet could be used as an equivalent of this device, which has similar efficiency under same switching frequency. Thanks a lot.
Han
The parameters needed are:
R_DS (on); Ids for R_DS (on); Vgs for R_DS (on)
Gate-Source Threshold Voltage, Vth
Channel modulation, L
ohmic resistance of source and drain
Input, reverse transfer and output capacitance
